Author Topic: What's wrong with "REM"?  (Read 6959 times)
Re: What's wrong with "REM"?
« Reply #15 on: September 03, 2008, 07:32:24 AM »
bye all.
« Reply #16 on: September 03, 2008, 08:21:04 AM »
I don't expect other people to do my homework , or study for me
When the information in the "manual" is incomplete, or worse, inaccurate, then what ...
Considering in lisp, that expressions are evaluated from inside out, it would make perfect sense to expect that (+ sum a) would produce a value that can be used with rem. Clearly there is an error somewhere, either with the use of addition in a rem statement, or with the values returned by addition of real numbers. Without looking into the lisp engine itself, it would be impossible to know where the problem lies, but suffice to say, this is a problem, and very likely a bug. So to that point, to insist that someone RTFM to find a resolution to a potential bug, is both unhelpful and unwarranted. I guess I expect too much ...
Glenn R
« Reply #17 on: September 05, 2008, 12:17:53 PM »
Good call Kerry.
Spike Wilbury
« Reply #18 on: September 05, 2008, 12:23:22 PM »
And for those no English speaking/culture swampers, what this RTFM means?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #19 on: September 05, 2008, 12:55:59 PM »
It means, Please Kindly read the documentation… or something like that
« Reply #20 on: September 05, 2008, 12:56:32 PM »
RTFM is not an appropriate response in this case.
http://www.netlingo.com/lookup.cfm?term=RTFM
  • Custom Title
« Reply #21 on: September 05, 2008, 03:56:53 PM »
Read The Fine Manual
Glenn R
« Reply #22 on: September 05, 2008, 04:00:19 PM »
 :lmao:
Spike Wilbury
« Reply #23 on: September 05, 2008, 04:13:57 PM »
OK... it is make sense now, I just sent a letter to my boss using that, waiting for his response...   (instead of regards, i used the rtfm, thanks to you guys!)
« Last Edit: September 05, 2008, 04:22:04 PM by LE »
Dinosaur
« Reply #24 on: September 05, 2008, 05:26:36 PM »
Was that your current / old boss or the possible future / new boss?
Spike Wilbury
« Reply #25 on: September 05, 2008, 05:52:25 PM »
was joking.... :evil:
I had some fun, at least I laugh today....
 :lmao:
