Author Topic: Problems and Solutions Links (don't reinvent the wheel ...)  (Read 111543 times)
Re: Problems and Solutions Links (don't reinvent the wheel ...)
« Reply #60 on: February 17, 2013, 12:05:41 PM »
Looks like it has been removed for most sites.
Perhaps this one will work for you.
http://www.docstoc.com/docs/91142454/ABCs-of-AutoLISP-by-George-Omura-Book
I've reached the age where the happy hour is a nap. ()
LibertyOne
ymg
« Reply #63 on: September 16, 2013, 12:12:01 PM »
ssget function reference
Lee,
This is a great reference.
ymg
danallen
« Reply #64 on: September 16, 2013, 06:47:02 PM »
Does anyone have a good book to recommend for all the vla stuff?  (e-book would be nice) I know my way around entget/entmod, but I'm just stumbling with basics on vla, learning as I go when I see good code from others.
Just stumbled across an AutoLISP book,  free download:
http://www.4shared.com/get/ISEYpgpJ/6200_The_AbcS_Of_Autolisp_-_Om.html
Haven't read it yet.
LE3
« Reply #65 on: September 16, 2013, 07:03:13 PM »
Dan,
Have a look here:
AutoCAD expert's Visual LISP
http://en.togores.net/home
http://lispexpert.blogspot.com/
« Reply #66 on: September 16, 2013, 07:44:25 PM »
Luis,  I noticed that Reinaldo has mentioned theSwamp and Owen at OpenDCL in his Acknowledgements.
He's been writing about Lisp for quite a while and does a good job of the subject I think.
--> Donate to theSwamp<--
danallen
« Reply #67 on: September 16, 2013, 07:48:24 PM »
Dan,
Have a look here:
great, I'll take a look. Haven't bought a lisp book since Roy Harkow's in '96
« Reply #68 on: September 16, 2013, 07:52:10 PM »
Dan,
I don't have the book ... I have the 4 Kindle e-books which I believe make up the book.
LE3
« Reply #69 on: September 17, 2013, 09:42:18 AM »
Hi Kerry,
Yes, he is good!
« Reply #70 on: December 02, 2013, 07:05:26 AM »
« Reply #72 on: February 16, 2017, 05:09:00 PM »
Not sure if this has been posted in here or not, but when looking for information for xdata, I found this link
http://www.autodesk.com/techpubs/autocad/acadr14/dxf/dxf_group_codes.htm
Which when I look at the viewport entity, it listed the meanings of the xdata group codes.  I have never seen them listed before.  Even though it is for an old version, the codes (mostly) should still be the same.
BIGAL
  • 30 + years of using Autocad
« Reply #73 on: February 18, 2017, 08:28:01 PM »
Like kerry the e-books were only $8 each so bought all 4 for less than 1 paper version.
Rustabout
« Reply #74 on: June 29, 2020, 11:07:03 PM »
Vector Images for Dialog Boxes
I haven't tried this out myself yet, but I think it's an amazing piece of code. The author didn't get enough recognition and the amazing potential this utility can produce has never really been shown off:
http://www.theswamp.org/index.php?topic=20878.msg391581#msg391581
When first stumbled upon this I was full-on into learning about DCL (my weakest area when working with LISP). Other things prevented me from trying this out.
I personally think Vector images are better than Slide Images if you can use them for a few reasons.
