Author Topic: Problems and Solutions Links (don't reinvent the wheel ...)  (Read 162661 times)
Re: Problems and Solutions Links (not reinventing the wheel ...)
« Reply #15 on: September 17, 2009, 06:50:37 AM »
Updating my index this AM so I thought I would post it.
Kerry asked me if I had such a reference & I didn't at the time. So I've started keeping  one.
Sorry for the repeats from other post.
Index of Swamp Articles & Code - by CAB
AND Links to Programing Guides
This list...   http://www.theswamp.org/index.php?topic=24700.msg359343#msg359343
-------------  LISP  Logic  -----------------
http://www.theswamp.org/index.php?topic=13046.msg158557#msg158557  by CAB
http://www.cadtutor.net/forum/showthread.php?52365-localizing-variables
-------------  ERROR Handling   --------------
There's an Error in My Visual LISP® Code. Now What?
http://www.lukewarmcoffee.com/cad/AUGI%20-%20There%27s%20an%20Error%20in%20My%20Visual%20LISP%20Code.%20Now%20What.pdf
----------  SET function  -------------------
http://www.theswamp.org/index.php?topic=27226.msg328317#msg328317
http://www.theswamp.org/index.php?topic=27226.msg328322#msg328322
http://www.theswamp.org/index.php?topic=33088.0
-------------   Break & Trim   -----------------
http://www.theswamp.org/index.php?topic=10370.0  Break Objects by CAB - Break objects with crossing objects
http://www.theswamp.org/index.php?topic=24646.0  Trim with objects [CookieCutter] by Joe Burke
http://www.theswamp.org/index.php?topic=21324.msg258512#msg258512  by RonJon
-----------   Line Type Loader /  Maker  ----------------
http://www.theswamp.org/index.php?topic=23888.0  LineType Loader by CAB - function to load a list of linetypes
http://www.theswamp.org/index.php?topic=31115.0 Advanced Linetype Loader  by Lee Mac
http://www.theswamp.org/index.php?topic=21339.msg258481#msg258481  LineType maker by RonJ
-------------   Offset  -----------------
Advanced Offset to both side by VVA <Vladimir Azarko>
Offset selected object to both side and change (optional) layer of new object to current
http://www.theswamp.org/index.php?topic=23069.0
http://www.theswamp.org/index.php?topic=32743.0 VLA-Offset using Point Selection
http://www.theswamp.org/index.php?topic=24688.0 Staggered Multiple Offset by RonJonp
http://www.theswamp.org/index.php?topic=6209.0 Here is a nice example of Offset by Jürg Menzi
http://www.theswamp.org/index.php?topic=23921.0 Offset direction discussion
http://www.theswamp.org/index.php?topic=21933.msg266096#msg266096 Offset Segments by Gile
-----------   Length and Area   ------------------
Length of Objects by CAB - pick each object & displays
the object type, length & a running total on the command line.
http://www.theswamp.org/index.php?topic=5891.0
http://www.theswamp.org/index.php?topic=5891.msg268984#msg268984
Lengthen Command with Options by CAB - lengthen command
with key press switch  from Lengthen to Shorten
http://www.theswamp.org/index.php?topic=23871.0
http://www.theswamp.org/index.php?topic=29270.0 Line Length Calculator by Lee Mac
http://www.theswamp.org/index.php?topic=20345.0 Areas of objects by Mark Thomas
http://www.theswamp.org/index.php?topic=33671.0  Show Total by Andrea
----------  Lengthen Command   -------------
http://www.theswamp.org/index.php?topic=23871.0  Lengthen Command with Options
-------------  Increment Number  -----------------
Incremental Numbering Tool & Automatic Numbering by Lee McDonnell
http://www.theswamp.org/index.php?topic=28727.msg349955#msg349955
http://www.theswamp.org/index.php?topic=518.0  Increment Number in Text by CAB
http://www.theswamp.org/index.php?topic=20907.0   Increment the suffix of a string by Gile
http://www.theswamp.org/index.php?topic=28727.0   Incremental Numbering Tool by Lee Mac
http://www.theswamp.org/index.php?topic=12867.msg157064#msg157064 by Tim Willey
----------  WCMATCH  --------------
http://www.theswamp.org/index.php?topic=28210.0
http://www.theswamp.org/index.php?topic=5004.msg60485#msg60485
http://www.theswamp.org/index.php?topic=28210.msg337978#msg337978
http://www.theswamp.org/index.php?topic=28210.msg337979#msg337979
http://www.theswamp.org/index.php?topic=27733.msg333229#msg333229
----------  Align Text  ---------------
http://www.theswamp.org/index.php?topic=25824.0  Align Text CAB
http://www.theswamp.org/index.php?topic=8903.msg367635#msg367635 Tim Willey / CAB
http://www.theswamp.org/index.php?topic=29153.0  Align Text to Curve by Lee Mac
http://www.cadtutor.net/forum/showthread.php?37646-Align-Text-to-Curve
http://www.theswamp.org/index.php?topic=33735.0  Slinky Text by Lee Mac
http://www.theswamp.org/index.php?topic=30943.0  LeeMac text2object reactor
----------  Insert Text  --------------
http://www.theswamp.org/index.php?topic=1392.0 CAB
----------  Box Text by CAB   -------------
http://www.theswamp.org/index.php?topic=7003.0  CAB
Bounding Box for Groups of Plain Text [Older Version]
http://www.theswamp.org/index.php?topic=6045.0
-----------  Text Style  -------------
Merge text styles (or change text styles)  by Tim Willey
http://www.theswamp.org/index.php?topic=17659.0
-------------  Sorts  --------------------
http://www.theswamp.org/index.php?topic=16564.0
http://www.theswamp.org/index.php?topic=6474.0
http://www.theswamp.org/index.php?topic=30262.0
--------------   Bounding Box  ------------------
http://www.theswamp.org/index.php?topic=15323.msg188915#msg188915
http://www.theswamp.org/index.php?topic=15323.msg190278#msg190278
http://forums.augi.com/showpost.php?p=902301&postcount=2
http://www.theswamp.org/index.php?topic=32597
http://www.theswamp.org/index.php?topic=20534.msg250025#msg250025
DTdeformer ! Dynamic Text Deformer...   [By Andrea]
http://www.theswamp.org/index.php?topic=30197.0
--------------  Match Properties  -----------------
http://www.theswamp.org/index.php?topic=8163.0
http://www.theswamp.org/index.php?topic=5185.msg62997#msg62997
http://www.theswamp.org/index.php?topic=19857.msg266746#msg266746
http://www.theswamp.org/index.php?topic=23560.0
http://www.theswamp.org/index.php?topic=8940.msg115052#msg115052
--------------  Clone / Copy  Text  ----------------
Clone Text Object by CAB - Clone one text string from dText mText
or Attribute to other selected dText mText or Attribute object
http://www.theswamp.org/index.php?topic=6874.0
http://www.theswamp.org/index.php?topic=30368.0  CopyText.lsp v1.3 by Alan J. Thompson (alanjt)
http://www.theswamp.org/index.php?topic=28685.0  SwapText by Joe Burke
http://www.theswamp.org/index.php?topic=19805.msg241476#msg241476  Copy 2 Clipboard VVA
http://www.theswamp.org/index.php?topic=21764.msg263566#msg263566
http://www.theswamp.org/index.php?topic=30451.0  txt2mtxt w/ copy option LeeMac
--------  Message Box Utility   -------------------
http://www.theswamp.org/index.php?topic=31107.0  Another MessageBox utility by Keith
-------------   Viewport Routines -------------------
http://www.theswamp.org/index.php?topic=2509.0 Lock CAB
http://www.theswamp.org/index.php?topic=7097.0 Lock CAB
http://www.theswamp.org/index.php?topic=9461.msg129670#msg129670  VP Outline Tim & CAB
-------------   Isolate Layer   -------------------
http://www.theswamp.org/index.php?topic=30392.0 Isolate object  by Tim Willey
http://www.theswamp.org/index.php?topic=30142.0 Isolate nested layers  by RonJonp
http://www.theswamp.org/index.php?topic=9131.msg117714#msg117714  by CAB
http://www.theswamp.org/index.php?topic=34490.0 by John
-------------   Layer Import / Create   -------------------
http://www.theswamp.org/index.php?topic=23805.0
http://www.theswamp.org/index.php?topic=23805.msg288265#msg288265  Import Layers
http://www.theswamp.org/index.php?topic=8763.0  Layer Creator by Kerry
http://www.theswamp.org/index.php?topic=12845.msg156899#msg156899
http://www.theswamp.org/index.php?topic=23805.msg288356#msg288356
http://www.theswamp.org/index.php?topic=2414.0
---------  Lisp Autoload  -------------
http://www.theswamp.org/index.php?topic=28857.0
http://www.theswamp.org/index.php?topic=20492.0
http://www.theswamp.org/index.php?topic=3023.msg39485#msg39485
http://www.theswamp.org/index.php?topic=2439
http://www.theswamp.org/index.php?topic=9211.0
http://www.theswamp.org/index.php?topic=9211.msg118838#msg118838  Create a file to autoload - MP
http://www.theswamp.org/index.php?topic=34610.0   Create a file to autoload - RonJonp
---------  Zoom Object  -------------
http://www.theswamp.org/index.php?topic=20534.0
----------  Entmake   ----------------------
http://www.theswamp.org/index.php?topic=31145.0  ENTMAKE function by CAB
http://www.theswamp.org/index.php?topic=4814.msg112107#msg112107
http://www.theswamp.org/index.php?topic=17445.0  Min codes
----------   Boundary   ------------------
 External Contour of Objects  by VVA
http://www.theswamp.org/index.php?topic=26664.0
----------------  HATCH  -------------------------
http://www.theswamp.org/index.php?topic=33975.0  delete all hatches  by VVA
http://www.theswamp.org/index.php?topic=10371.0
http://www.theswamp.org/index.php?topic=6412.msg78804#msg78804
http://www.theswamp.org/index.php?topic=26463.0
----------  Remove a LWpolyline Vertex  --------
http://www.theswamp.org/index.php?topic=19865.0
http://www.theswamp.org/index.php?topic=5251.0
http://www.theswamp.org/index.php?topic=10344
------------  Remove  Bulge  ---------------
http://www.theswamp.org/index.php?topic=34134.0  Tim Willey
-----------  Add a  LWpolyline Vertex  ------------
http://www.theswamp.org/index.php?topic=18720.0
http://www.theswamp.org/index.php?topic=30170
-----------  Polyline Reverse  -------------------
http://www.theswamp.org/index.php?topic=12618.msg155016#msg155016  gile
http://www.theswamp.org/Themes/oxygen11final/images/post/xx.gif Evgeniy
http://www.theswamp.org/index.php?topic=32603.0  alanjt
http://www.theswamp.org/index.php?topic=1116.msg14511#msg14511 CAB 2004
http://www.theswamp.org/index.php?topic=12618.msg198982#msg198982 CAB
http://www.theswamp.org/index.php?topic=1116.msg14514#msg14514
-----------  Point Inside Pline  -------------------
http://www.theswamp.org/index.php?topic=7785.0
http://groups.google.com/group/autodesk.autocad.customization/browse_thread/thread/6ec20cba1a1f9efe/79056df13e3f42b1?q=%40cv_inside+group:autodesk.autocad.customization#79056df13e3f42b1
http://groups.google.com/group/autodesk.autocad.customization/attach/42682170bb9ac419/%40cv_inside.lsp?part=2
-----------  Centroid  --------------
http://www.cadtutor.net/forum/showpost.php?p=268885&postcount=4  ; gile cent
http://www.theswamp.org/index.php?topic=27429.msg330461#msg330461
http://www.theswamp.org/index.php?topic=18725.msg346553#msg346553
---------------  Xref   ----------------------
http://www.theswamp.org/index.php?topic=3104.0  Batch xref attach to overlay
http://www.theswamp.org/index.php?topic=23515.0  Unload/Reload/Detach XREF's
http://www.theswamp.org/index.php?topic=24251.msg293032#msg293032  CopyNestedLayer
http://www.theswamp.org/index.php?topic=32382.0  Finding Blocks in xref
http://www.theswamp.org/index.php?topic=28062.0  List xref inserts and nested ones by Tim
----------  Blocks & Inserts -----------------
Swap Blocks
http://www.theswamp.org/index.php?topic=15234.msg184871#msg184871
http://www.theswamp.org/index.php?topic=13283.0
http://www.theswamp.org/index.php?topic=2272.0
http://www.theswamp.org/index.php?topic=28965.0
http://www.theswamp.org/index.php?topic=22479.0
Code to look at modifying:
http://www.theswamp.org/index.php?topic=17085.msg206807#msg206807
http://www.theswamp.org/index.php?topic=22999.0
http://www.theswamp.org/index.php?topic=23017.0  Update all blocks in drawing by Keith
Directly add blocks defined in any drawing file, to the current drawing. by TT
http://www.theswamp.org/index.php?topic=1821.msg24017#msg24017
Blocks, What's in there?  CAB
http://www.theswamp.org/index.php?topic=29953.0
List blocks, nested blocks, xrefs into a structured list.
Topic: How to list all the blocks in a directory form?
http://www.theswamp.org/index.php?topic=28043.msg336481#msg336481  By MP
http://www.theswamp.org/index.php?topic=31524.msg370964#msg370964  by Tim Willey
http://www.theswamp.org/index.php?topic=29988.msg355655#msg355655  by Lee Mac
http://www.theswamp.org/index.php?topic=176.0  by Craig
http://www.theswamp.org/index.php?topic=3935.0 by whdjr
----------   ACAD Fileds   ------------
http://www.theswamp.org/index.php?topic=33884.0
http://www.theswamp.org/index.php?topic=34974.0
----------  Attribute Modifying  -------
http://www.theswamp.org/index.php?topic=10216.0
http://www.theswamp.org/index.php?topic=14194.msg171057#msg171057
http://www.theswamp.org/index.php?topic=4172.msg49951#msg49951
http://www.theswamp.org/index.php?topic=4172.msg49956#msg49956
Extract attributes from block or multileader w/block  by AlanJT
http://www.theswamp.org/index.php?topic=29917.0
Multiple Attribute Modification by Lee Mac
http://www.theswamp.org/index.php?topic=29397.0
http://www.theswamp.org/index.php?topic=29124.0
    ----  ObjectDBX Block Modify Attributes -----
http://www.theswamp.org/index.php?topic=8661.msg120358#msg120358
http://www.theswamp.org/index.php?topic=13532.msg163961#msg163961
http://www.theswamp.org/index.php?topic=7335.msg91135#msg91135
------   ObjectDBX  ----------
http://www.theswamp.org/index.php?topic=29933.msg354958#msg354958]Loop Drawings & execute a lisp
http://www.theswamp.org/forum/index.php?topic=7335.msg91135#msg91135]Re: Change the same details of a number of drawing titleblocks
http://www.theswamp.org/forum/index.php?topic=6307.0]DBX Testing
http://www.theswamp.org/forum/index.php?topic=7498.0]run a lisp in dwgs WITHOUT opening the dwgs?
http://www.theswamp.org/forum/index.php?topic=3650.0]Jeff_M or anyone familiar with ObjectDBX
http://www.theswamp.org/forum/index.php?topic=2671.0]Find Text in a Closed Drawing
http://www.theswamp.org/forum/index.php?topic=1821.0]Block Adding
http://www.theswamp.org/index.php?topic=22932.msg275882#msg275882]Copy various collections
http://www.theswamp.org/index.php?topic=22932.msg275940#msg275940]Copy a Layout
http://www.theswamp.org/index.php?topic=29933.0   MapDbxDocs  by Tim Willey
http://www.theswamp.org/index.php?topic=31827.0  by Lee Mac
--------------  Find / Replae Text  ----------------------
http://www.theswamp.org/index.php?topic=4591.msg272347#msg272347
--------------  Structures in AutoLISP   -------------------
http://www.theswamp.org/index.php?topic=29356.0  by Herman
-----------    (vlax-release-object obj) vs (setq obj nil)     -------------------
http://www.theswamp.org/index.php?topic=2005.0
--------------  Layout Export / Copy  -------------------
Create separate drawings for each layout  by Tim Willey
http://www.theswamp.org/index.php?topic=19721.msg240368#msg240368
Copy Objects to Layouts by Tim Willey
http://www.theswamp.org/index.php?topic=29111.0
Copy Objects to Layouts by Will DeLoach
http://www.theswamp.org/index.php?topic=3012.0
----------  grread examples   ---------
http://www.theswamp.org/index.php?topic=12813.0  Examples of usage GRREAD
http://www.theswamp.org/index.php?topic=27747.0  Pline Star for fun!
http://www.theswamp.org/index.php?topic=25412.0  Text Command
http://www.theswamp.org/index.php?topic=18537.0  Detail Indicator
http://www.theswamp.org/index.php?topic=29187.msg347277#msg347277  Draw a circle dynamically
http://www.theswamp.org/index.php?topic=26774.0  DBMAN Dynamic Blocks Manipulator
http://www.theswamp.org/index.php?topic=27479.0  DLMO Dynamic Line Modeler !
http://www.theswamp.org/index.php?topic=29245.0  Dynamic Intelligent Leader
http://www.theswamp.org/index.php?topic=25195.0  Leadering Text...
----------  entsel examples  ----------
http://www.theswamp.org/index.php?topic=6992.0
http://www.theswamp.org/index.php?topic=11342.msg143630#msg143630
-----------   keyword examples  -------------
http://www.theswamp.org/index.php?topic=15173.0
----------  Save / Backup DWG with Thumbnail  ----------------
with ARX
http://www.theswamp.org/index.php?topic=14394.0
http://www.theswamp.org/index.php?topic=12035.msg150963#msg150963
with NET
http://www.theswamp.org/index.php?topic=24524.msg296051#msg296051
http://www.theswamp.org/index.php?topic=28457.0  Backup Reactor
http://www.theswamp.org/index.php?topic=24992.0  VBA version
http://www.theswamp.org/index.php?topic=4735.0
http://www.theswamp.org/index.php?topic=4735.msg81888#msg81888
http://www.theswamp.org/index.php?topic=17552.msg212071#msg212071
http://www.theswamp.org/index.php?topic=8499.0
---------- Folders & Files  ---------------
http://msdn.microsoft.com/en-gb/library/bb774065%28VS.85%29.aspx
http://www.theswamp.org/index.php?topic=9229.msg369104#msg369104
http://www.theswamp.org/index.php?topic=3499.0
http://www.theswamp.org/index.php?topic=30704.0
----------  Block Library Manager  --------------
http://www.theswamp.org/index.php?topic=32058.0
----------  Title Blocks  -------------------
http://www.theswamp.org/index.php?topic=8661.0
----------  Selection Sets  ----------------
http://www.theswamp.org/index.php?topic=1915.0  Select By Layer or Color
http://www.theswamp.org/index.php?topic=8451.0
http://www.theswamp.org/index.php?topic=8794.0
http://www.theswamp.org/index.php?topic=33979.msg393046#msg393046 determine which segment of the pline is selected
http://www.theswamp.org/index.php?topic=34793.msg400060#msg400060  gile
http://www.theswamp.org/index.php?topic=34793.msg400059#msg400059 Lee Mac
-----------  Set the Text Editor in ACAD  --------------------
http://www.theswamp.org/index.php?topic=14567.msg273739#msg273739
(setvar "dtexted" 1)
----------  Tips & Tricks for ACAD  -----------------------
http://www.theswamp.org/index.php?topic=14567.0
-----------  MLeaders  ----------------
http://www.theswamp.org/index.php?topic=22949.msg276576#msg276576  DrawMleader by Crank
;;  addd Mleader with attributed block & edit the attribute
http://www.theswamp.org/index.php?topic=24732.msg298189#msg298189
;;; Tip 2305: LeaderToMleader.lsp   Leader to Multileader   (c) 2008 Lyle Hardin
-----------  Draw Perpendicular Lines  -------------
Draw perpendicular line by Alan J. Thompson, 10.15.09
http://www.theswamp.org/index.php?topic=12813.msg369597#msg369597
Extend point as needed to make perpendicular by ronjonp
http://www.theswamp.org/index.php?topic=1468.msg326292#msg326292
-----------  Logand  ----------------
http://tinyurl.com/dnpl5
--------------   Rounding  ---------------------
http://www.theswamp.org/forum/index.php?topic=3076.0
http://www.theswamp.org/index.php?topic=8511.msg109002#msg109002
very cool link about rounding
http://en.wikipedia.org/wiki/Rounding#Round-to-even_method
http://www.theswamp.org/index.php?topic=4747.msg57268#msg57268
-----------  Leaders  ----------------
http://www.theswamp.org/index.php?topic=6383.0  Add a vertex to a Leader
Oops, exceeded max post size, will add another post.
« Last Edit: September 22, 2010, 09:35:04 PM by CAB »
Krushert
  • FREE BEER Tomorrow!!
« Reply #16 on: September 17, 2009, 12:28:45 PM »
Most excellent list CAB.  Thanks
KewlToyZ
« Reply #17 on: September 18, 2009, 09:17:59 AM »
Good grief, nice index CAB thanks! :kewl:
« Reply #18 on: December 19, 2009, 09:25:36 AM »
Thanks,
Updated my index post.
kdub in one timeline.
--> Donate to theSwamp<-
Krushert
« Reply #20 on: December 20, 2009, 07:33:56 PM »
Thanks Kerry.  I was looking for that just the other day.  I remember reading some time ago but could not recall what to search for.
« Reply #21 on: February 06, 2010, 07:17:13 AM »
My update exceeded the max post size so the remainder I will post here:
-----------  Ldata - xData -------------
Quick XData Functions by Lee Mac
http://www.theswamp.org/index.php?topic=30445.0
http://www.theswamp.org/index.php?topic=31804.0
http://www.theswamp.org/index.php?topic=1283.0  Ldata vs xData
http://www.theswamp.org/index.php?topic=4395.0
http://www.theswamp.org/index.php?topic=8829.0
http://www.theswamp.org/index.php?topic=29381.0
http://www.theswamp.org/index.php?topic=23294.msg281024#msg281024
http://www.theswamp.org/index.php?topic=18054.msg218567#msg218567
http://www.theswamp.org/index.php?topic=29564.0
http://www.theswamp.org/index.php?topic=18490.0  Ldata example
---------  DCL  ----------------
http://web2.airmail.net/terrycad/Tutorials/MyDialogs.htm  by TerryCAD
http://www.jefferypsanders.com/autolisp_DCL.html
http://www.opendcl.com/forum/
http://www.theswamp.org/index.php?board=63.0  OpenDCL at the Swamp
----------  List Manipulation   --------------
http://www.theswamp.org/index.php?topic=31473.0  list & car cadr etc
http://ronleigh.info/autolisp/afude09.htm
http://www.cadtutor.net/forum/showpost.php?p=258390&postcount=20  apostrophe by Lee
-----------  Reactor  ----------------
http://www.theswamp.org/index.php?topic=26380.0  Length Rector by CAB
http://www.theswamp.org/index.php?topic=8710.0  Object Reactor
http://www.theswamp.org/index.php?topic=10248.0  AreaReactor Thread
http://www.theswamp.org/index.php?topic=22733.msg273953#msg273953  Layer Create Reactor CAB
http://www.theswamp.org/index.php?topic=28604.msg349372#msg349372
-----------   Close DWG Reactors  -----------
http://www.theswamp.org/index.php?topic=12986.msg157991#msg157991
http://www.theswamp.org/index.php?topic=12986.msg158077#msg158077
http://www.theswamp.org/index.php?topic=26752.msg322500#msg322500
Darray15.lsp  [By Andrea]
I have created this New Dynamic Array function.
The only thing I don't like...is the way i've made it by using block..
but it work great. so if some one have any suggestions to doing this without creating block
I will be happy to see it.
http://www.theswamp.org/index.php?topic=26633.0
Ncloud11.lsp  [By Andrea]
There is my version of Cloud..
Ncloud v.1.0 (New Cloud)
this is diffrent of Dcloud and use simple Pline against blocks.
allow you to draw a cloud and see it dynamicly what is look like before draw.
also,..with Ncloud you can use TAB to reverse each buldge independent or Shift+TAB to reverse all buldge dynamicly during creation.
Ncloud allow you to have open or closed cloud if your pointer are close of the start point it will close automaticly.
you can see these 2 gif below for example.
http://www.theswamp.org/index.php?topic=27545.0
Dhatch4[1]5.lsp  [By Andrea]
I have created a new way to hatch...
H.O.S.  v.1 (Hatch Object Scaling)
this allow user to select a closed polyline and scale in real time the hatch !
you can switch to the next Hatch patern by pressing the TAB key.
http://www.theswamp.org/index.php?topic=26444.0
DLMO Dynamic Line Modeler !  [By Andrea]
It will create and modify your entity Dynamicly !
For Now, I have make these Kind of edition:
"TRIM" "PICKER" "WAVE" "BUBBLE" "TRAPEZE" "SQUARE" "ROUNDED" "TWISTED" "SMOOTHTWISTED" "CANDLE"
DBMAN Dynamic Blocks Manipulator !   [By Andrea]
Dynamic Block MANipulator allow user to chage Dynamicly the scale, rotation and
location for block have same name in your drawing without selecting all.
D H L I N E  [By Andrea]
Dynamic Hidden Line v.1.0
You can now draw any line without specifying level.
DHLINE auto-detect the entity made on same layer. but you can
filter entity as your need.
http://www.theswamp.org/index.php?topic=27051.0
Dpush v.1.0 [By Andrea]
D y n a m i c   P u s h
Allow user to push entity with a line.
Use SHIFT to move the Line and Release to Rotate.
http://www.theswamp.org/index.php?topic=29923.0
Dynamic Offset by Lee Mac
http://www.theswamp.org/index.php?topic=30650.0
Dynamic Text Streatch  by Lee Mac
http://www.theswamp.org/index.php?topic=30578.0
----------  Miscellaneous  ---------------
[AutoCAD Installation] Personal Step by Step Guide
http://www.theswamp.org/index.php?topic=31678.0
-----------  Programing References  ------------
http://www.autodesk.com/techpubs/autocad/acad2000/dxf/index.htm   DXF Codes
http://www.analogx.com/contents/articles/howtoprg.htm  So you want to be a Programmer...
http://pages.cs.wisc.edu/~vernon/cs367/notes/6.RECURSION.html  Recursion
http://jefferypsanders.com/autolisp.html
http://www.geocities.com/siliconvalley/2151/matrices.html
Volume 1 of The Art of Computer Programming
http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html#%_toc_start    CONTENTS
http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-38.html#%_index_start    INDEX
« Last Edit: September 22, 2010, 09:36:21 PM by CAB »
rhino
« Reply #22 on: February 11, 2010, 11:52:09 PM »
@CAB
This should be in your list too  8-):
[added kdub]
worked examples of
IF
COND
OR
AND
PROGN
WHILE functions
[rhino]
and a perfect explanation of each of those functions!
« Last Edit: February 12, 2010, 02:36:41 AM by rhino »
« Reply #23 on: February 12, 2010, 09:47:09 AM »
Thanks,
I forgot about that post.
It will be included in the next update to the list. :)
VVA
« Reply #24 on: February 22, 2010, 03:09:46 AM »
http://www.asmitools.com/Files/Programs.html
http://www.asmitools.com/Files/Tutorials.html
Post ASMI
Quote from: ASMI;296771
It is possible that some of you have noticed that the site AsmiTools no longer works due to unpaid hosting services. This is my conscious decision and not due to lack of funds. My present work has nothing to do with AutoCAD, and I find it difficult to maintain this site, as well as participate in this wonderful forum. I say goodbye to your friends. In this archive with all the AsmiTools, lisps each of you can use them as he wants. Perhaps they can be placed in AutoLISP Archive at this site. If someone wants to use my site, I will give it, write me at asmirnov#inbox.lv.
Now I end my membership at the forum and erase my account.
Goodbye friends, thanks for everything.
AsmiTools AutoLISP Archive
« Reply #25 on: February 22, 2010, 03:20:39 AM »
Thanks Vladimir.
« Reply #26 on: February 22, 2010, 08:30:59 AM »
Thanks, the link has been revised.. :-(
« Reply #27 on: March 26, 2010, 01:26:06 PM »
I don't think this has been linked to yet:
FYI... List xref inserts and nested ones
[ http://www.theswamp.org/index.php?topic=28062.0 ]
« Reply #28 on: June 17, 2010, 09:50:34 AM »
Updated my two post of links.  8-)
VVA
« Reply #29 on: September 14, 2010, 04:12:09 AM »
----- Copy Block --------
Copies a selected block using a new name specified by the
user, matching scale and rotation. Works with Dynamic Blocks.
CopyBlock by VVA
Copy Block by Lee Mac
