Author Topic: Getting focus back from status bar button  (Read 3241 times)
Peter Laker
« on: August 27, 2008, 06:09:12 AM »
I have been playing around with some status bar buttons & have found that when you print a message to the text screen from a button press you loose focus on the command line. See Pic
Does anyone know how you can get the focus back on the command line.
A sample of the code is below.
using System;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.Windows;
namespace buttons
    public class PaneButtons
        //test to see if button is loaded
        static bool buttonLoaded = false;
        [CommandMethod("BTEST")]
        public static void PaneButton()
            Pane appPaneButton = new Pane();
            //Set the buttons properties
            appPaneButton.Enabled = true;
            appPaneButton.Visible = true;
            appPaneButton.Style = PaneStyles.Normal;
            appPaneButton.Text = "B-Test";
            appPaneButton.ToolTipText = "This is a command prompt test.";
            if(buttonLoaded == false)
                //Hook into the MouseDown event to run code when the button is pressed.
                appPaneButton.MouseDown += new StatusBarMouseDownEventHandler(OnAppMouseDown);
                //Add the button to the applications status bar
                //Items can also be added to the tray area
                acadApp.StatusBar.Panes.Add(appPaneButton);
                buttonLoaded = true;
        private static void OnAppMouseDown(object sender, StatusBarMouseDownEventArgs e)
            //open editor
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Pane paneButton = (Pane)sender;
            if(paneButton.Style == PaneStyles.PopOut)
                paneButton.Style = PaneStyles.Normal;
                ed.WriteMessage("\n<activated>\n");
            else
                paneButton.Style = PaneStyles.PopOut;
                ed.WriteMessage("\n<de-activated>\n");
            acadApp.StatusBar.Update();
Glenn R
Re: Getting focus back from status bar button
« Reply #1 on: August 27, 2008, 06:12:21 AM »
AutoCAD version?
.Net Framework version?
Visual Studio version (if used)?
Glenn R
« Reply #2 on: August 27, 2008, 07:11:53 AM »
used autoCAD 2006 and Visual Studio Express 2008 C#:
using System;
namespace buttons
if (buttonLoaded == false)
//open editor
if (paneButton.Style == PaneStyles.PopOut)
ed.WriteMessage("{0}<activated>", Environment.NewLine);
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
else
ed.WriteMessage("{0}<de-activated>", Environment.NewLine);
Updated your code and added a reference to 'acmgdinternal.dll'
Cheers,
Glenn.
Peter Laker
« Reply #3 on: August 27, 2008, 07:20:21 AM »
Thanks Glenn much appreciated.
Been using this with Autocad 2008 & VS 2008 pro.
