Author Topic: Selecting object and point?  (Read 10763 times)
« Reply #15 on: September 21, 2004, 10:44:28 AM »
This is how great programming is developed ... by users helping users ....
Ok .. lemme wipe the tear from my eye ...
« Reply #16 on: September 21, 2004, 12:03:32 PM »
Quote from: Keith
heyheyheyhey.............
whdjr
« Reply #17 on: September 21, 2004, 01:42:23 PM »
Cab,
Tested you function & found that it crashed if the 'Pick Point' was not on an object.
That is you picked out in space.
Thanks for your insight on the code.  I didn't post my ss_get function, but it doesn't allow for missed or empty selection sets.
(defun ss_get (lst / ent)
  (while (not ent)
    (prompt "\nSelect side to extend:  ")
    (cond ((setq ent (ssget lst)))
 ((= (getvar "ErrNo") 52)
  (exit)
 ((null ent)
  (princ "\nSelection missed.  Please try again.")
  ent
BUT (and its a big one), if the pline your after is not in the selection set then the program returns an empty selection set ( and thats BAD).
I also felt that the WHILE loop
only needed to test the pt var as it will only have a value if the object was found.
Also changed ( or sel ( null sel )) because it is always true. null sel does not test
for an empty selection set.
So I removed some code per your advise and added more:
(while (not pt)
  (setq sel (ss_get ":E:S"))
  (mapcar '(lambda (x)
    (if (not (eq x obj))
      (ssdel x sel)
 (ssnames sel)
  (if (and sel (/= 0 (sslength sel)))
    (setq ent (ssname sel 0)
 pt  (last (last (car (ssnamex sel 0))))
    (princ "\nPoint not on Polyline.  Please try again. ")
If you know of a better way to tell if a selection set is empty please let me know.
Thanks.
whdjr
« Reply #18 on: September 21, 2004, 01:44:03 PM »
Keith,
Do you need a Kleenex buddy?
« Reply #19 on: September 21, 2004, 02:15:55 PM »
Quote from: Mark Thomas
Quote from: Keith
Sorry ... I only said it because it is the epitome of happiness in that different users can share code, improve, expand their personal knowledge .. never meant it as an insult ....
whdjr
« Reply #20 on: September 21, 2004, 02:25:20 PM »
No insult taken.  Just poking fun.
By the way, how do you get the quote function in the forum to display who wrote the quote?  Mine doesn't display.
« Reply #21 on: September 21, 2004, 02:32:47 PM »
Quote from: Keith
Quote from: Keith
It wasn't taken that way either. Perhaps my keyboard skills are some what lacking. "heyheyheyhey...." was meant to be laughter, with you not at you.
« Reply #22 on: September 21, 2004, 02:33:04 PM »
you must do the following in your opening quote ....
Quote from: Put something here
If you do that then it will work without problem...
The above code will look like this:
Sombody said this
whdjr
« Reply #23 on: September 21, 2004, 02:57:53 PM »
Quote from: This is cool stuff.  Thanks Keith
Like that?
Cool!
Thanks,
« Reply #24 on: September 21, 2004, 03:31:10 PM »
Not to criticize but to show you the normal convention of how things are coded.
In your ss_get routine, the name ss_get implies that you are going after a selection set.
'ent' is used for entites and 'ss' for selection sets, & 'lst' for list.
There may only be one entity in you selection set but it is still a selection set.
I see, as you say the ss_get will not return nil so the IF I had added is not needed.
Also not needed is the test in the next IF ( and ss because the ss will always be a
selection set with 0 or 1 entity in it. See the revised code.
(defun c:test (/ sel obj pt ent)
  (setq obj (car (entsel "\nPick ent to match."))
        pt  nil
  (prompt "\nSelect point on object.")
  (while (not pt) ; only valid when obj is selected
    (mapcar
        '(lambda (x)(if (not (eq x obj)) (ssdel x sel)))
        (ssnames sel)
    (if (> (sslength sel) 0)
(defun ssnames (ss / idx lst)
  (setq idx (sslength ss)
        lst (list)
  (while (>= (setq idx (1- idx)) 0)
    (setq lst (cons (ssname ss idx) lst))
(defun ss_get (lst / ss)
  (while (not ss)
    (cond ((setq ss (ssget lst)))
            (exit)) ; ENTER pressed
          ((null ss)
            (princ "\nSelection missed.  Please try again."))
  ss ; return a selectionset, never nil
whdjr
« Reply #25 on: September 21, 2004, 03:45:20 PM »
I see your point exactly and I thank you for illustrating that.
Actually I made the same routine for the entsel command and then just changed it to work with ssget for this application.
(defun ent_sel (msg / ent)
  (while (not ent)
    (cond ((setq ent (entsel msg)))
 ((= (getvar "ErrNo") 7)
  (exit)
  ent
I have another question (hehe, this is tricky, haha).
In your example you show "pt" as a local var on the first line, therefore until you assign it a value it will be "nil".  So why do set it to nil in the first statement of the code?
This is me being curious.  I have seen others do it as well, but if "pt" is already "nil" why set it "nil" again.[/code]
« Reply #26 on: September 21, 2004, 04:03:49 PM »
Good question. :)
This was a 'Test' function and the code may have been copied to a larger routine.
That is to say the local pt may then be global and as pt is a common var name I
want to be sure it was nil when the while was executed for the first time.
So it was a CYA move on my part.
« Reply #27 on: September 21, 2004, 04:10:29 PM »
And another thing. When I wrote the first draft of the routine I had no
local vars declared. I often do that during debugging early on in a routine.
It gets me in trouble with vars that need to be some value and I run the routine.
The vars are set to something & are global, then I run the routine again and I
start scratching my head  :shock: as to why the routine is behaving a certain way.
whdjr
« Reply #28 on: September 21, 2004, 04:22:29 PM »
Quote from: CAB
Is this a common practice in Florida?
You know...picking bugs off ones self...
<snicker><snicker>
It is here in Georgia.
<haha>
Big fat ugly mosquitos.
« Reply #29 on: September 21, 2004, 04:37:43 PM »
I have stayed in the mountains of north GA many times during even the middle of the summer and never have I had the misfortune of being bitten by a mosquito.
Hijacked thread now returned to original owner ...
