i tried to draw a circle with COM via PyAcad.Net and it worked.
from System import Array,Type
import clr
clr.AddReferenceToFileAndPath(r"c:\Program Files\IronPython\Tutorial\AutoCAD.dll") #path to the assembly generated from acax17enu.tlb by tlbimp.exe from netsdk
from AutoCAD import *
import Autodesk.AutoCAD.ApplicationServices as ap
doc = ap.Application.DocumentManager.MdiActiveDocument.AcadDocument
acadApp = doc.Application
doc.ActiveSpace == AcActiveSpace.acModelSpace
pnt = Array.CreateInstance(Type.GetType("System.Double"),3)
for i,coord in enumerate(doc.Utility.GetPoint(Prompt = "\ncenter of the circle: ")):
pnt.SetValue(coord,i)
circle = doc.ModelSpace.AddCircle(pnt,100)
circle.color = ACAD_COLOR.acMagenta
acadApp.ZoomExtents()
