Here is a modified version.
If you stretch the dimension to <=48" it will change to inches.
But stretching the other way does not work yet. I'm pondering what to do when there are existing xdata overrides present.
The current routine overwrites existing xdata.
This is a test release.
Alan,
have a look at this update, it works here back and forward, and even with matchprop too... please ignore the code enchilada I just did.
Notes:
1. I did not understood the cond usage the part "AcDbRadialDimension" - I thought that was taking care on "DIMRADIUS" - me might wrong.
2. I reuse my previous if's calls
3. Added a new function to change the xdata, but this can be place on a single function, merge fractional-dim and fractional-dim-arch
4. hth
5. almost forgot....
so where are the swamp lispers ?
