I was using code to grab the images from a drawing, and tried it on 06.
I got an error that the dbDictionaryEntry could not be found in the acdbmgd.dll and went to check in the object browser in VS.
I had not noticed this before, because my references are set to the 2008 versions, and I test on 2008 generally.
Sure enough, set to 06 versions and it ain't there. I hate it when the computer knows what its talking about.
I went back and looked at code from Tony T and Tim W, and realized there might be a good reason they used dxf codes to look through images.
Was this the reason, or is there some dll import step I need to do to get the ability to look at dictionaryentries in 2006?
thanks as always.
