Author Topic: Center of curve  (Read 1820 times)
Gliderider
Center of curve
« on: August 14, 2008, 09:21:25 AM »
I'm attempting to write a routine to return the PI (point of intersection) of a curve (either simple arc or polyline arc). I was hoping someone could give some direction on how to return the radius point of a poyline arc.
Gliderider
Re: Center of curve
« Reply #1 on: August 14, 2008, 10:46:12 AM »
Never mind... I was trying to make it harder than it needed to be, sometimes you can't see the forest for the trees...
sorted it with
(setq ent (entsel)
        pt  (osnap (cadr ent) "nea")
crv-rp (osnap pt "cen"))
cjw
Re: Center of curve
« Reply #2 on: August 22, 2008, 01:28:31 AM »
hopes this link can help you...
http://www.afralisp.net/lisp/Bulges1.htm
TimSpangler
  • CAD Naked!!
Re: Center of curve
« Reply #3 on: August 22, 2008, 07:19:29 AM »
Are you talking about the center point?
ACA 2015 - Windows 7 Pro
Gliderider
Re: Center of curve
« Reply #4 on: August 22, 2008, 07:29:57 AM »
Yes, Center point/Radius point; tomato, tomahto
Daniel J. Ellis
Re: Center of curve
« Reply #5 on: August 22, 2008, 08:53:57 AM »
i.e. one's right, one's wrong? lol
DJE
dJE
Re: Center of curve
« Reply #6 on: August 22, 2008, 10:57:46 AM »
Here's a fine tutorial from Mr. Madsen.
http://www.theswamp.org/index.php?topic=467.0
Gliderider
Re: Center of curve
« Reply #7 on: August 22, 2008, 11:13:34 AM »
Thanks Mark and Mr. Madsen, that's very informative. I always wondered what 'Parameters' were.
