Try this update.
Note that .ls is a backup file type. When you save, the file type will be .lsp and you don't have to enter that!
;;; CopyRotate.lsp by Charles Alan Butler
;;; Copyright 2008
;;; by Precision Drafting & Design All Rights Reserved.
;;; Contact at TheSwamp.org
;;; Version 5.2 Sep 04, 2008
;;; DESCRIPTION
;;; User pick base point then selects object(s)
;;; Paste mode until Escape is pressed
;;; Once pasted user selects rotation angle
;;; Command Line Usage
;;; Command: copyr
;;;;; Copy objects, then paste & rotate new copy
(defun c:copyr (/ pt npt ss elast ssnew ale_lastent ale_ss-after *error*
MoveStarted osmodetmp usrosmode)
;; error function & Routine Exit
(defun *error* (msg)
(not
(member
msg
'("console break" "Function cancelled" "quit / exit abort" "")
) ; endif
(and usrosmode (setvar "osmode" usrosmode))
(if (and MoveStarted ssnew)
(command "._erase" ssnew "")
;; Rune Wold and Michael Puckett - modified ale_lastent ale_ss-after
(defun ale_lastent (/ entnam outval)
(and
(setq outval (entlast))
(while (setq entnam (entnext outval))
(setq outval entnam)
outval
(defun ale_ss-after (entnam / entnxt selset)
((not entnam) (ssget "_X"))
((setq entnxt (entnext entnam))
(setq selset (ssadd entnxt))
(while (setq entnxt (entnext entnxt))
(if (entget entnxt)
(ssadd entnxt selset)
selset
(setq usrosmode (getvar "osmode"))
(setq osmodetmp (getvar "osmode"))
(if (and (null (prompt "\nSelect objects to copy:"))
(setq ss (ssget))
(setq pt (getpoint "\nPick base point:"))
(setvar "osmode" 0)
(command "._copybase" pt ss "")
(command "._undo" "_begin")
(setq elast (ale_lastent))
(command "._pasteclip" pt) ; Create a Copy
(setq ssnew (ale_ss-after elast))
(while
(setq MoveStarted t)
(setvar "osmode" 0)
(command "._move" ssnew "" pt)
(setvar "osmode" osmodetmp)
(command pause)
(if (or (and (null npt) (setq npt (getvar "lastpoint")))
(> (distance pt (setq npt (getvar "lastpoint"))) 0.0001))
;; allow user to rotate
(setvar "osmode" 0)
(command "._rotate" ssnew "" npt)
(command pause)
(setq MoveStarted nil)
(command "._undo" "_end")
;; get last item in database
(setvar "osmode" 0)
;; get new items pasted.
t ; stay in loop
) ; while
) ; progn
) ; endif
(*error* "")
