Author Topic: Deleting font styles  (Read 4550 times)
jonesy
  • SuperMod
« on: August 12, 2008, 04:01:11 AM »
I am currently "cleaning house" on a set of drawings before they get issued to a client.
These drawings SHOULD have just 2 text styles (apart from the one/two ACAD creates) I need to delete all the "extra" text styles. There are no drawing frames, so there are no "nested" fonts. I have used the QSelect to change all the text and the MText to the correct font, but there is still a long list of fonts that shouldnt be in the drawing, which I cant delete. How do I find out where the fonts are being used?
Many thanks in advance
T :-)
Rob...
Re: Deleting font styles
« Reply #1 on: August 12, 2008, 07:15:39 AM »
By fonts, I'm assuming your mean "Text Styles".
The text associated with those styles could be "hidden" in blocks, dimension styles, complex linetypes, even empty text objects. (Yes, some people still manage to make them.) I would start with blocking the drawing into a clean file. That will eliminate any empty text objects, blocks, and anything else you can't select using window selection. Check to see if those styles are still there. If so, begin checking dimension styles and any blocks that reside in the drawing.
CAD Tech
jonesy
  • SuperMod
« Reply #2 on: August 12, 2008, 07:28:27 AM »
Thanks for your reply Rob
I had already deleted the empty text strings, purged blocks etc. I'd not thought about the complex linestyles, so I shall go searching down that route.
Oh how I wish it were easy to track down the text styles :(
Gliderider
« Reply #3 on: August 12, 2008, 07:54:45 AM »
This may help, look here for Txtmrg
http://www.texupport.net/cadinfo/downloads/index.php
jonesy
  • SuperMod
« Reply #4 on: August 12, 2008, 08:00:50 AM »
Thanks for that link... looking into that now.
Rob...
« Reply #5 on: August 12, 2008, 08:09:14 AM »
Holy cow. I feel like I just hit the motherlode. Awesome tools, thanks for sharing that link, lpseifert. I've suddenly come to the realization that I'm obsessively organized when it comes my drawing files.
CAD Tech
jonesy
  • SuperMod
« Reply #6 on: August 12, 2008, 10:33:29 AM »
After extensive digging around, I have now managed to delete the text styles that shouldnt be there.
It seems that it had something to do with the Mtext being "over-ridden". Once I had removed all the formatting from all the text I could delete the last 2 incorrect text styles. (I didnt think this would have anything to do with it)
Hedgehog
« Reply #7 on: August 12, 2008, 11:00:28 AM »
There's a routine called STRIPMTEXT.lsp (google-able) that can be used to selectively eliminate text formatting... I use it quite a bit  :-)
jonesy
  • SuperMod
« Reply #8 on: August 12, 2008, 11:49:50 AM »
Does that work in 2008. (or is it operator error)
I've tried to get it to load in my software and I keep getting an error
; error: bad argument type for compare: 17 15.0
Hedgehog
« Reply #9 on: August 12, 2008, 11:57:21 AM »
Ah... the version I have also has a .dcl file & I know works in 2007-2009... see attchment.
jonesy
  • SuperMod
« Reply #10 on: August 12, 2008, 12:02:15 PM »
Thanks Hedge... the version I found was version 2.1 and that wasnt working.
This one works great :)
Cheers
T :-)
CHulse
« Reply #11 on: August 13, 2008, 09:14:32 AM »
Man after my own heart!
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
CHulse
« Reply #12 on: August 13, 2008, 09:15:02 AM »
Cary Hulse
« Reply #13 on: August 13, 2008, 11:25:45 AM »
There is also this file I did to merge text styles.  Just another way to skin the cat since you already found one that worked.
[ http://www.theswamp.org/index.php?topic=17659.0 ]
jonesy
  • SuperMod
« Reply #14 on: August 13, 2008, 04:13:07 PM »
Thanks Tim
I'll take a look at that too... Looks like it could be very useful as I have loads of drawings to go through
