Author Topic: Calling ConvertToStaticBlock() on a Table.  (Read 3372 times)
tjr
« on: August 07, 2008, 01:30:54 PM »
Does anyone have any experience with converting tables to static blocks using the above method? It's a void with an optional string arguement but whenever I call it i get some database error. I'm looking to know when I should call this thing and any example snippets would help me a lot.
Re: Calling ConvertToStaticBlock() on a Table.
« Reply #1 on: August 07, 2008, 02:01:00 PM »
I would get the error also, but you can do it this way.
[CommandMethod( "TestTableToBlock" )]
public void TestTableToBlock() {
Document Doc = acadApp.DocumentManager.MdiActiveDocument;
Database Db = Doc.Database;
Editor Ed = Doc.Editor;
using ( Transaction Trans = Db.TransactionManager.StartTransaction() ) {
PromptEntityResult per = Ed.GetEntity( "\n Select table: " ) as PromptEntityResult;
Table tbl = Trans.GetObject( per.ObjectId, OpenMode.ForWrite ) as Table;
BlockTableRecord LoRec = Trans.GetObject( Db.CurrentSpaceId, OpenMode.ForWrite ) as BlockTableRecord;
BlockReference BlkRef = new BlockReference( tbl.Position, tbl.BlockTableRecord );
LoRec.AppendEntity( BlkRef );
Trans.AddNewlyCreatedDBObject( BlkRef, true );
tbl.Erase();
Trans.Commit();
tjr
« Reply #2 on: August 07, 2008, 02:44:38 PM »
Thanks I'll try that.
Glenn R
« Reply #3 on: August 07, 2008, 04:22:58 PM »
From memory, a table is implemented as an anon block of the form '*TSomeNumberHere', the '*' being the cue for an anon block. I would suggest trying to get that block from the Table object, then you have a 'standard' acad block.
Glenn R
« Reply #4 on: August 07, 2008, 04:25:14 PM »
Also, in these sort of situations, post the following:
Acad Version
.NET Framework version
Visual Studio version
what .NET Framework version you are targeting
Error you are getting
Test code for others to play along.
« Reply #5 on: August 07, 2008, 04:44:45 PM »
You are correct, and that is how I did it.
Glenn R
« Reply #6 on: August 07, 2008, 04:47:23 PM »
My apologies Tim - after re-reading your code (which I just scanned as it's late here) you are doing what I suggested.
« Reply #7 on: August 07, 2008, 04:54:22 PM »
No problem.  I'm glad I was on the right track.   :-)
tjr
« Reply #8 on: August 07, 2008, 06:47:27 PM »
Acad Version
It is boo code written in a development build of Sharpdevelop3. I don't know if many others would have wanted to play along with that.   :-) I agree that I should have posted my acad version as well as the error though.
