Author Topic: a lisp to keep my palettes in order  (Read 8116 times)
deegeecees
Re: a lisp to keep my palettes in order
« Reply #15 on: August 06, 2008, 03:27:32 PM »
can it be turned off at will
Its basically an I/O switch. You can still manipulate the caps lock manually if you want to.
deegeecees
« Reply #16 on: August 06, 2008, 03:31:23 PM »
...should I copy this file to my support path, or should I just create a blank file?
Copy the one in the sample folder. AutoCad looks for this file every time you start up. From the looks of things, it hasn't been available through your support path, so it moves on. When you put this file in your support path, it will see it and load every time you start AutioCad.
SKUI_BREAKER
« Reply #17 on: August 06, 2008, 03:35:02 PM »
oh i forgot to add the autolay lsp that makes it all possible
sorry though i cant add the vlr-manager.fas because when i open it up all i see is squares  ex.  Q   _Ò     2 Q  j
;;;load VLISP extensions
(vl-load-com);initialize VLISP extensions
;;;load the reactor manager
(if (member nil (atoms-family 1 '("vlr-manager" "vlr-family" "vlr-object" "vlr-object-p" "vlr-syntax")))
  (load "VLR-Manager")
;toggles autolay on and off
(defun c:autolay (/ funcs file)
  (setq funcs '(c:autolay al:autolay al:cmdbegin al:cmdcancelled al:color al:cmdend al:disable al:exist al:layerstate al:linetype al:loadtype al:lweight al:mklayer al:putinlist al:reactorload))
      (not (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\AutoLay" "AutoLay"));is AutoLay turned on or off in the registry?
      (member nil (atoms-family 1 (mapcar 'vl-princ-to-string funcs)));are any AutoLay subfunctions not loaded
      (setq file (findfile "AutoLay[3.0].lsp"))
      (vl-registry-write "HKEY_CURRENT_USER\\SOFTWARE\\AutoLay" "AutoLay" "T");set registry for AutoLay enabled
      (load file);load "AutoLay[3.0].lsp"
      (vl-registry-delete "HKEY_CURRENT_USER\\SOFTWARE\\AutoLay" "AutoLay");set registry for AutoLay disabled
      (mapcar
       '(lambda (x)(set x nil));set all AutoLay subroutines to nil
        (vl-remove 'c:autolay (vl-remove 'al:putinlist funcs));except for the ones needed to re-enable AutoLay
      );set AutoLay subroutines to nil
      (vlr-manager '(VLR-DWG-reactor nil '((:VLR-beginClose . al:disable))) 1);remove reactor
      (vlr-manager '(VLR-Command-reactor nil '((:VLR-commandWillStart . al:autolay)(:VLR-commandEnded . al:autolay)(:VLR-commandCancelled . al:autolay))) 1);remove reactor
      (princ "\nUnloaded AutoLay[3.0].lsp")
(defun al:putinlist (a d l)
    ( (not l)(list (cons a d)));if no list, create association list in a list
    ( (not (assoc a l))(cons (cons a d) l));if no association in list, create one
    ( (subst (cons a d)(assoc a l) l));if association in list, replace it
(if (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\AutoLay" "AutoLay");if AutoLay is enabled in the registry, continue loading
(defun al:autolay (reactor info / cmd crn dat)
  (setq cmd (car info);get command
        crn (vlr-current-reaction-name);get the name of the reactor calling this function
        dat (vlr-data reactor);get data list from reactor object
    ( (and
        (= crn ':VLR-commandWillStart);is command starting?
        (not (assoc 'COMMAND dat));has a association to 'COMMAND been assiged to the reactor data to eliminate problems with transparent commands?
      (vlr-data-set reactor (al:putinlist 'COMMAND cmd dat));assign an association to 'COMMAND to the reactor data list
      (al:cmdbegin reactor info);call the layer manipulating routine
    ( (and
        (= crn ':VLR-commandEnded);is command ending?
        (equal cmd (cdr (assoc 'COMMAND dat)));is the association to 'COMMAND assiged to the reactor data equal to the command that filed the reactor?
      (vlr-data-set reactor (vl-remove (assoc 'COMMAND dat) dat));Remove association to 'COMMAND in reactor data list
      (al:cmdend reactor info);restore previous layer status
    ( (and
        (= crn ':VLR-commandCancelled);was command cancelled?
      (al:cmdcancelled reactor info);restore previous layer status and remove new layer if one was created
;;;tests the command name, textsize, dimtext size etc.
;;;to determine if action needs to be taken. This is where the layer name
;;;comes from and where the conditions under which to act under are set up.
(defun al:cmdbegin (reactor info / ado cmd dat dsc dst dtx tst tsz)
  (setq cmd (car info);get the command
        dat (vlr-data reactor);get reactor data
        ado (cdr (assoc 'ado dat));get pointer to activeDocument
        dsc (vlax-variant-value (vla-getvariable ado "dimscale"));get scale
        dst (strcase (vla-get-name (vla-get-activedimstyle ado)));get dimstyle
        dtx (vlax-variant-value (vla-getvariable ado "dimtxt"));get dimtxt size
        tst (strcase (vla-get-name (vla-get-activetextstyle ado)));get textstyle
        tsz (vlax-variant-value (vla-getvariable ado "textsize"));get text size
  );end setq
    ( (wcmatch cmd "HATCH,BHATCH");is the command "hatch"?
      (al:layerstate reactor info "Hatch");make, thaw, turn on and make current "Hatch" layer as needed
    );end cond 1
    ( (wcmatch cmd "VPORTS");is the command "vports"?
      (al:layerstate reactor info "Viewport");make, thaw, turn on and make current "Viewport" layer as needed
    );end cond 2
    ( (wcmatch cmd "DIM,BREAKLINE,DIMLINEAR,DIMALIGNED,DIMORDINATE,DIMRADIUS,DIMDIAMETER,DIMANGULAR,DIMBASELINE,DIMCONTINUE,QDIM,LEADER,QLEADER");are you creating a dimension?
      (al:layerstate reactor info "Dim2");make, thaw, turn on and make current "Dim" layer as needed
    );end cond 3
    ( (wcmatch cmd "DIMCENTER");are you creating a center mark?
      (al:layerstate reactor info "Center");make, thaw, turn on and make current "Dim" layer as needed
    );end cond 4
    ( (wcmatch cmd "DTEXT,MTEXT,TEXT");are you creating text?
      (al:layerstate reactor info "Text");make, thaw, turn on and make current "Text" layer as needed
    );end cond 5
  );end cond
);end defun
;;;figures out what action needs to be taken by checking
;;;the state of the layer "name" and the command being used
(defun al:layerstate (reactor info name / clo cmd lso lyo lon frz lck lof lyr)
        ado (cdr (assoc 'ado dat));get pointer to activeDocument object
        clo (vla-get-ActiveLayer ado);get the clayer object
        lso (cdr (assoc 'lso dat));get pointer to layers object
        lyo (al:exist lso name);get the layer object for "name"
  );end setq
  (if lyo;does layer not exist?
      (if (= (vla-get-LayerOn lyo) :vlax-false);is layer off?
          (vla-put-LayerOn lyo :vlax-true);turn it on
          (setq lon (list 'vla-put-layeron lyo :vlax-false));save an expression to turn off later via al:cmdend
        );end progn
      );end if
      (if (= (vla-get-Freeze lyo) :vlax-true);is layer frozen?
          (vla-put-Freeze lyo :vlax-false);thaw it
          (setq frz (list 'vla-put-freeze lyo :vlax-true));save an expression to refreeze later via al:cmdend
        );end progn
      );end if
      (if (= (vla-get-Lock lyo) :vlax-true);is layer locked?
          (vla-put-Lock lyo :vlax-false);unlock it
          (setq lok (list 'vla-put-lock lyo :vlax-true));save an expression to lock it again later via al:cmdend
        );end progn
      );end if
    );end progn
    (setq lyo (al:mklayer reactor info name);make it
          dat (al:putinlist 'NLR lyo dat);add to data list to be stored in reactor object incase of commandCancelled event
  );end if
      (wcmatch cmd "BHATCH,HATCH,BREAKLINE,DIMLINEAR,DIMALIGNED,DIMORDINATE,DIMRADIUS,DIMDIAMETER,DIMANGULAR,DIMBASELINE,DIMCONTINUE,QDIM,LEADER,QLEADER");is the command is "*hatch"*
      (setq lof (if (wcmatch cmd "BHATCH,HATCH")(al:exist lso "Hidden")(al:exist lso "Hatch")));sets the value of LOF to the hidden layer object or nil depending on the results of al:exist
      (= (vla-get-LayerOn lof) :vlax-true);on
      (= (vla-get-Freeze lof) :vlax-false);thawed
    );end and
      (vla-put-LayerOn lof :vlax-false);turn "hidden" layer off
      (setq lof (list 'vla-put-layeron lof :vlax-true));add to data list to be stored in reactor object for commandEnded or commandCancelled event
    );end progn
  );end if
  (if (not (equal clo lyo));if layer is not current
      (vla-put-ActiveLayer ado lyo);sets layer current
      (setq lyr (list 'vla-put-activelayer ado clo));add to data list to be stored in reactor object for commandEnded or commandCancelled event
  );end if
  (setq dat (al:putinlist 'LAYDAT (vl-remove nil (list lyr lon lof frz lok)) dat));compile data
  (vlr-data-set reactor dat);commit data to reactor object
);end defun
;;;creates layer, sets properties and returns layer object
(defun al:mkLayer (reactor info name / ado dat lso lyo color lineType lineWeight val)
  (setq dat       (vlr-data reactor)
        lyo       (vla-add lso name);create the layer
        name      (strcase name);set "name" to all capitols
        color     (al:color name);get color
        lineType  (vla-get-name
                    (al:loadLinetype reactor info
                      (al:ltype name);get linetype
                      (if (= (vlax-variant-value (vla-getvariable ado "measureinit")) 0);English or metric
                        "acad.lin"; load linetype from English linetype file
                        "acadiso.lin"; load linetype from metric linetype file
                      );end if
                    );end al:loadlinetype
                  );end vla-get-name
       lineWeight (al:lweight name)
  );end setq
  (if lyo; if the layer was made, (lyo not nil)
    (foreach prop '(color lineType lineWeight);loop therugh properties
      (if (setq val (eval prop))
        (vlax-put-property lyo prop val);set the properties for layer "name"
      );end if
    );end foreach
  );end if
  lyo; return layer object to calling function
);end defun
;;;attempts to load linetype if not loaded
;;;returns linetype object name if loaded else nil
(defun al:loadlinetype (reactor info name fname / dat linetypes)
        linetypes (cdr (assoc 'linetypes dat))
  (if (not (al:exist linetypes name));linetype is not loaded
    (vl-catch-all-apply
       'vla-load (list linetypes name fname);load it, unfortunately vla-load returns nil on success or error on fail instead of linetype object
    );trap error if load fails
  );end if
  (al:exist linetypes name);return linetype object if exists, else nil
);end defun
;;;returns ActiveX object if exist, else nil
(defun al:exist (collection item / rslt)
    (not
      (vl-catch-all-error-p
        (setq rslt
          (vl-catch-all-apply 'vla-item
            (list collection item)
          );trap error
        );end setq
      );return T if successful, else nil
    );end not
    rslt; return object or nil
  );end if
);end defun
;;;returns lineTypeName according to layer standard for "name"
;;;edit linetypes according to your layer standard
(defun al:ltype (name)
    ((wcmatch name "BREAK") "phantom");break layer, phantom linetype
    ((wcmatch name "CENTER") "center2");center layer, center2 linetype
    ((wcmatch name "HIDDEN") "hidden");hidden layer, hidden linetype
    (T "continuous");if "name" not found return "continuous" linetype
  );end cond
);end defun
;;;returns lineweight (enumerated, metric equivelant) according to layer "name"
;;;edit lineweights according to your layer standard
;;;valid values are:
;;;acLnWtByBlock, acLnWtByLwDefault,
;;;acLnWt000, acLnWt005, acLnWt009, acLnWt013
;;;acLnWt015, acLnWt018, acLnWt020, acLnWt025
;;;acLnWt030, acLnWt035, acLnWt040, acLnWt050
;;;acLnWt053, acLnWt060, acLnWt070, acLnWt080
;;;acLnWt090, acLnWt100, acLnWt106, acLnWt120
;;;acLnWt140, acLnWt158, acLnWt200, acLnWt211
(defun al:lweight (name / color)
    ((wcmatch name "CENTER,DIM") acLnWt020);red, 0.008"
    ((wcmatch name "TEXT") acLnWt015);blue, 0.006"
    ((wcmatch name "HATCH,HIDDEN") acLnWt009);magenta, 0.004"
    ((wcmatch name "VIEWPORT") acLnWt053);white, 0.021"
    (T acLnWtByLwDefault);if "color" not found return default lineweight
  );end cond
);end defun
;;;returns color (intiger) for layer "name"
;;;edit colors according to your layer standard
(defun al:color (name)
    ((wcmatch name "CENTER,DIM") 1)
    ((wcmatch name "DIM2,OBJECT_MEDIUM,PIPE,TEXT,TITLE") 5)
    ((wcmatch name "HATCH,HIDDEN") 6)
    ((wcmatch name "Viewport") 7)
    (T (acad_colordlg 1 nil));if "name" not found bring up color dialog
  );end cond
);end defun
;;;upon completion of command restores lso to previous state
(defun al:cmdend (reactor info / dat ldt)
  (setq dat (vlr-data reactor);get reactor data
        ldt (assoc 'LAYDAT dat);get saved expressions to restore layer
        dat (vl-remove ldt dat);remove LDT from data list
  (mapcar 'eval (cdr ldt));evaluate elements of LDT
(defun al:cmdcancelled (reactor info / dat nlr)
        nlr (assoc 'NLR dat);get pointer to newly created layer
        dat (vl-remove nlr dat);remove NLR from data list
  (al:cmdend reactor info);restore previous layer state
  (if nlr (vla-delete (cdr nlr)));delete newly created layer if any
;;;disables commandEnded reactor to avoid errors when using "new" and "open"
;;;in SDI mode. The error is merely annoying and only appears at the command
;;;line as "error: no function definition: al:restore" when opening or creating
;;;a new drawing. The cause of the error is commandEnded reactor present form
;;;last dwg but LISP has not yet loaded the called function in a new or opened
;;;dwg. Furthermore, the reactor cannot be removed because it has already been
;;;activated and is waiting for the command to end. Therefore, the reactor must
;;;be rendered non-functional by changing its call to the LISP command "LIST".
(defun al:disable (reactor info)
  (if (= (vlax-variant-value (vla-getvariable (vlr-data reactor) "sdi")) 1);in SDI mode?
    (vlr-reaction-set
      (car (vlr-object '(VLR-Command-reactor nil '((:VLR-commandWillStart . al:autolay)(:VLR-commandEnded . al:autolay)(:VLR-commandCancelled . al:autolay)))))
      :VLR-commandEnded
      'list;the only function I could find that would work without errors
  );end if
);end defun
;;;Here's where we construct the reactors to do all this cool stuff
(defun al:reactorload (/ ado dat)
  (setq ado (vla-get-ActiveDocument (vlax-get-acad-object));get pointer to activeDocument
        dat     (list;create a list of associations to pointers for use during the entire drawing session
  (cons 'ado ado);store pointer to activeDocument
                  (cons 'lso (vla-get-layers ado));get and store pointer to layers collection
                  (cons 'linetypes (vla-get-linetypes ado));get and store pointer to linetypes collection
                );end list
  );end setq
  (vlr-manager '(VLR-DWG-reactor ado '((:VLR-beginClose . al:disable))) 3);construct reactor to call 'al:disable' on beginClose event
  (vlr-manager '(VLR-Command-reactor dat '((:VLR-commandWillStart . al:autolay)(:VLR-commandEnded . al:autolay)(:VLR-commandCancelled . al:autolay))) 3);construct reactor to call 'al:cmdbegin' on commandWillStart commandEnded and commandCancelled events
(al:reactorload);excecute reactor construction
;;;get rid of old reactor if present. The reactor will be present, because in
;;;SDI mode, it's associated namespace is not destroyed, but has the new drawing
;;;loaded into it. At the time this file is loaded, this reactor is either not
;;;present or has been rendered useless (in SDI mode) at the closing of the last
;;;dwg and is excess loaded code bulk and should be removed. The VLR-MANAGER
;;;provides an easy means of doing this.
(vlr-manager '(VLR-Command-reactor nil '((:VLR-commandWillStart . al:autolay)(:VLR-commandEnded . list)(:VLR-commandCancelled . al:autolay))) 1)
(princ "\nLoaded AutoLay[3.0].lsp\n")
  );end progn
  (princ "\nLoaded AutoLay[3.0].lsp. Type \"autolay\" to enable.")
);end if
Chris
« Reply #18 on: August 06, 2008, 03:35:18 PM »
i get a compile error, variable has not been defined
I believe it is referring to kbArray
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
SKUI_BREAKER
« Reply #19 on: August 06, 2008, 03:38:34 PM »
mine is very easy if you already have the vlr-manager file "or at lest i think its required"
all you do is save all thre of the lisp in seperate files then load then in to autocad.
Chris
« Reply #20 on: August 06, 2008, 03:42:26 PM »
yes, but it also says it requires doslib, and we dont have that installed.
Win 10
deegeecees
« Reply #21 on: August 06, 2008, 03:48:47 PM »
*forhead smack*
Aww geez, I forgot, you'll need to add this to the top of the file. Sorry folks, the old noggin slips up more so lately than ever.
Option Explicit
Private Const VK_CAPITAL = &H14
Private Type KeyboardBytes
    kbByte(0 To 255) As Byte
End Type
Private kbArray As KeyboardBytes
Private Declare Function GetKeyState Lib "user32" _
  (ByVal nVirtKey As Long) As Long
Private Declare Function GetKeyboardState Lib "user32" _
  (kbArray As KeyboardBytes) As Long
Private Declare Function SetKeyboardState Lib "user32" _
Private Declare Function GetForegroundWindow Lib "user32" () As Long
SKUI_BREAKER
« Reply #22 on: August 06, 2008, 03:51:09 PM »
a doslib i have no idea what that is
i do know that i have taken it to a few computers pasted it on hard drive and then added the 2 lisp and the vlr-manager.fas to autocad startup
and i was done of course they all had windows XP.
deegeecees
« Reply #23 on: August 06, 2008, 03:54:43 PM »
Some helpful info for you:
http://www.en.na.mcneel.com/doslib.htm
Chris
« Reply #24 on: August 06, 2008, 03:56:46 PM »
now how do I get it to load automatically, it seems I have to hit alt+f11  for the program to start working
Win 10
SKUI_BREAKER
« Reply #25 on: August 06, 2008, 03:58:42 PM »
i dont remember ever loading the doslib.exe but i have it now
and i also found this link to all the files i have talked about before.
every file that is needed is here including capslock.lsp
http://discussion.autodesk.com/servlet/JiveServlet/download/126-320799-2665920-26512/AutoLay[3.0].zip
deegeecees
« Reply #26 on: August 06, 2008, 04:01:40 PM »
If acad.dvb is in your support path structure, then all you have to do is start typing some DTEXT, or MTEXT, etc.
Chris
« Reply #27 on: August 06, 2008, 04:09:44 PM »
for some reason it doesnt work, I am going to look into the doslib,  I kind of have an issue with vba as it is being phased out.  it should be pretty easy to have the arx autoload using our exisitng setup and I'll just add an additional reactor to fire and run the capslock on and off toggle.  all the other programming seems to be overkill, it will take at most 5 lines of code to run the capslock toggle, base on the newer doslib help.
Win 10
deegeecees
« Reply #28 on: August 06, 2008, 04:20:54 PM »
If you're networked, then your Cad Manager must have a different copy of acad.dvb somewhere, so I woudn't mess with it.
Chris
« Reply #29 on: August 07, 2008, 08:16:39 AM »
we are networked, and I am the CAD Manager, but I am not that worried, I was really only going to set it up for me,  Controlling that is a little easier with a lisp routine.
Win 10
