Hello: I'm trying to figure out how to get a selection set from model space into my newly created paperspace:
When my application runs, the user often will open an existing drawing. Often time, there could be several drawings in model space and the user is generating a new drawing to go into this same model space. After, they need to get the new drawing into a custom template (new paperspace).
I created a BOM command that currently loads the custom template into a new paperspace. I still need to include code that will ask the user to select the objects from model space that they want to go into the new paperspace. This part I can do...
Here's the part I need help with...How do I get the objects the user selects into the new paperspace???
I think perhaps I will need to do a zoom extents; after that, I will need to write code that works like the MView... is this correct? am I on the right track?
here's my current BOM command (if it will help):
<CommandMethod("BOM")> (modified code originally derrived from Fatty)_
Sub BOM()
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor()
Dim num As Double = iModulesPerUnit 'this number represents the distance between the leds given the product chosen
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim idLayout As ObjectId = ObjectId.Null
'PARSE OUT WINDOWS AUTHENTICATION AUTHORIZATION TO GET THE FIRST,LAST INITIAL OF THE USER'S LOGIN
Dim sUserLoginInit As String
sUserLoginInit = UCase(wiUserLogin.Substring(0, 2))
Dim iIncrementText As Integer = 0
Dim myBT As DatabaseServices.BlockTable
Dim myBTR As DatabaseServices.BlockTableRecord
Dim myBTE As DatabaseServices.SymbolTableEnumerator
Dim myLayout As New DatabaseServices.Layout
Dim sLayoutName As String = ""
Dim sLayoutNameParsedRight As String
Dim sLayoutNameParsedRightRev As String
Using docLock As DocumentLock = ed.Document.LockDocument()
Using trans As Transaction = ed.Document.TransactionManager.StartTransaction()
Dim filename As String = "C:\Documents and Settings\rproctor\Local Settings\Application Data\Autodesk\AutoCAD 2008\R17.1\enu\Template\SLOAN_TEMPLATE_rev.dwt"
Dim layoutname As String = "Layout"
Dim sNewLayoutName As String = "SLOAN_LED"
Dim dbSource As New Database(False, False)
Try
dbSource.ReadDwgFile(filename, System.IO.FileShare.Read, True, Nothing)
Dim idDbdSource As ObjectId = dbSource.LayoutDictionaryId
Dim dbdLayout As DBDictionary = DirectCast(trans.GetObject(idDbdSource, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead, False, False), DBDictionary)
For Each deLayout As DictionaryEntry In dbdLayout
Dim sLayout As String = deLayout.Key.ToString()
If sLayout.ToUpper() = layoutname.ToUpper() Then
idLayout = DirectCast(deLayout.Value, ObjectId)
Exit For
End If
Next
If idLayout <> ObjectId.Null Then
Dim idc As New ObjectIdCollection()
idc.Add(idLayout)
Dim im As IdMapping = New IdMapping()
Dim dbdict As DBDictionary = DirectCast(trans.GetObject(db.LayoutDictionaryId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False, False), DBDictionary)
dbdict.UpgradeOpen()
db.WblockCloneObjects(idc, db.LayoutDictionaryId, im, DuplicateRecordCloning.MangleName, False)
Dim ip As IdPair = im.Lookup(idLayout)
idLayout = ip.Value
Dim lm As LayoutManager = LayoutManager.Current
lm.CurrentLayout = layoutname
dbdict.DecomposeForSave(DwgVersion.Current)
'LOOK TO SEE IF LAYOUT NAMED SLOAN_ESTIMATE ALREADY EXISTS
'if yes, look to see if sloan_estimate1 exists
'keep going till get unique layout name
myBT = db.BlockTableId.GetObject(DatabaseServices.OpenMode.ForRead)
myBTE = myBT.GetEnumerator
'ASSIGN UNIQUE LAYOUT NAME
While myBTE.MoveNext
myBTR = myBTE.Current.GetObject(DatabaseServices.OpenMode.ForRead)
If myBTR.IsLayout Then
myLayout = myBTR.LayoutId.GetObject(DatabaseServices.OpenMode.ForRead)
' MsgBox(myBTR.Name & vbCr & myLayout.LayoutName)
If InStr(myLayout.LayoutName, "SLOAN_ESTIMATE") = 1 Then
'if there's already a layout that has at least part of this name
' If InStr(1, myLayout.LayoutName, "SLOAN_ESTIMATE") = 1 Then
'see if there's anything concatenated with "SLOAN_ESTIMATE" LENGTH OF "SLOAN_ESTIMATE"=14
If myLayout.LayoutName.Length >= 14 Then
If sLayoutName = "" Then
sLayoutNameParsedRight = myLayout.LayoutName.Substring(14, myLayout.LayoutName.Length - 14)
If sLayoutNameParsedRight = "" Then
sLayoutNameParsedRight = "0"
End If
sLayoutName = "SLOAN_ESTIMATE" & (sLayoutNameParsedRight + 1)
Else
'Do a check of the new assignment
'if we had already assigned a new layout name, need to make sure there's not another like it
'check the number for the layout
End If
'here's the number it assigned to the last time. is it the same?
sLayoutNameParsedRightRev = sLayoutName.Substring(14, sLayoutName.Length - 14)
If sLayoutNameParsedRight = sLayoutNameParsedRightRev Then 'if it equals it, need to assign a new name
End If
End If
End If
End If
End If
End While
End If
LayoutManager.Current.RenameLayout("Layout", sLayoutName)
ed.Regen()
End If
Dim layoutObj As Layout = DirectCast(trans.GetObject(idLayout, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), Layout)
Dim layoutBtr As BlockTableRecord = trans.GetObject(layoutObj.BlockTableRecordId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, True)
Dim entId As ObjectId
Dim iIncrement As Integer = 0
For Each entId In layoutBtr
Dim ent As Entity = trans.GetObject(entId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, True)
'Debug.Print("ent type: " & vbTab & ent.GetType.ToString)
If TypeOf ent Is MText Then
Dim txt As MText
txt = CType(ent, MText)
' Debug.Print("text" & vbTab & txt.Contents.ToString)
If InStr(txt.Contents.ToString, "X", CompareMethod.Text) Then
Select Case iIncrement
Case 0
'FIRST TEXT BLOCK
'FILLS IN PRODUCT, COLOR, IOC, CAN DEPTH
'1st line:
txt.Contents = Replace(txt.Contents.ToString, "X", sModuleType.ToString, , 1)
txt.Contents = Replace(txt.Contents.ToString, "X", sLEDColor.ToString, , 1)
txt.Contents = Replace(txt.Contents.ToString, "X", iModulesPerUnit.ToString, , 1)
txt.Contents = Replace(txt.Contents.ToString, "X", inchesOnCenter.ToString, , 1)
txt.Contents = Replace(txt.Contents.ToString, "X", sVinylUsed.ToString, , 1)
'2nd line
'3rd line
txt.Contents = Replace(txt.Contents.ToString, "X", UCase(sCanDepth).ToString, , 1)
iIncrement = iIncrement + 1
Case 1
''2ND TEXT BLOCK
''FILLS IN PRODUCT, COLOR, IOC, CAN DEPTH
txt.Contents = Replace(txt.Contents.ToString, "X", dCountTotal.ToString, , 1)
End Select
End If
End If
If TypeOf ent Is DBText Then
Dim txt As DBText
txt = CType(ent, DBText)
If InStr(txt.TextString.ToString, "X", CompareMethod.Text) Then
Debug.Print("DBText" & vbTab & txt.TextString.ToString)
If iIncrementText = 0 Then
txt.TextString = Replace(txt.TextString.ToString, "X", sUserLoginInit.ToString, , 1)
End If
If iIncrementText = 1 Then
txt.TextString = Replace(txt.TextString.ToString, "X", Format(Now, "short date"), , 1)
End If
If iIncrementText = 2 Then
txt.TextString = Replace(txt.TextString.ToString, "X", sCustomer.ToString, , 1)
End If
If iIncrementText = 3 Then
txt.TextString = Replace(txt.TextString.ToString, "X", sCompanySignName.ToString, , 1)
End If
iIncrementText = iIncrementText + 1
End If
End If
Next
trans.Commit()
Catch ex As Autodesk.AutoCAD.Runtime.Exception
MsgBox(ex.StackTrace)
'MessageBox.Show(ex.ToString(), "Error", MessageBoxButtons.OK, MessageBoxIcon.[Error])
Finally
trans.Dispose()
dbSource.Dispose()
End Try
End Using
End Using
End Sub
Attatched is a pic how my BOM command currently runs. You can see that the pic isn't anywhere near the center of the viewport. The second pic shows how I need it to look.
Any thoughts, dirrection is truly appreciated.
proctor
