Author Topic: Move selected @ distance  (Read 1461 times)
V-Man
« on: July 29, 2008, 07:53:59 AM »
Ok, this is a real easy one for you guys. I am trying to make a command to ask the user to select on an object (1 at a time) then it would then move that object a certain distance away from it's original posistion and loop through until cancelled. This is what I have. Please don't laugh, it's early Tuesday morning?
(command c:lwf ()
(setq ss1 (ssget))
(command "move" ss1 "" "0,0" "2000'<180")
This does not work.
Don
Patrick_35
Re: Move selected @ distance
« Reply #1 on: July 29, 2008, 08:00:08 AM »
Hi
(defun c:lwf(/ sel)
  (while (setq sel (entsel))
    (command "_.move" (car sel) "" "0,0" "2000<180")
V-Man
« Reply #2 on: July 29, 2008, 08:04:34 AM »
Thanks Patrick_35  That's exactly it.
(defun c:lwf(/ sel)
« Reply #3 on: July 29, 2008, 12:04:14 PM »
If you ever want to move all at once use this:
(defun c:lwf (/ ss)
  (prompt "\nSelect items to move:")
  (if (setq ss (ssget))
    (command "_.move" ss "" "0,0" "2000<180")
V-Man
« Reply #4 on: July 30, 2008, 07:03:22 AM »
Thanks for the tip CAB
