Ok then.
I think I need to start over after reviewing some of this. I thought I was fine with the CUI because I was able to save and customize my own computer's files. When I try to do so in a more organized manner so I can keep the files on the server, and have all computers point at them... now I get cross eyed.
I'm going to keep my CASERibbon.cui that contains the additional tabs and panels.
I'm going to start over completely with the CUI. I'm restoring the default acad.cui that comes installed in C:\Documents and Settings\*user*\Application Data\Autoc... \Support\acad.cui
I will add the partial CUI's I create, such as the CASERibbon.cui. I think I can actually get by with -just- the CASERibbon.cui because it will contain the custom commands I need to use the buttons/flyouts I'll create, as well as all the new panels/tabs I created. I may split it into two partial CUIs, and keep the block library separate from the ribbon tabs that are for in-house macros for plotting, pdf'ing, title blocks, styles, and standard... but similar process.
So I think, for the sake of simplicity, every user will maintain their own CUI, locally, and also load the read-only partial CUI from the server.
Does this seem a sound idea? I'm mainly going off of your advice, Crank, because I think it would fit our environment better than having an enterprise CUI on the server that every is somewhat locked into. None of my users will ever customize the CUI anyways... I'm pretty much the only one that knows what the CUI is.
I'm also going to be giving a little refresher on "workspaces" because I think that'd take care of anything existing users want to do.
I appreciate your input, both of you. You've helped me get a little more understanding on how to use the CUI in a more sharing way
![Tongue :P](http://www.theswamp.org/Smileys/black/tongue.gif)
