Author Topic: ssget filter for dimscale  (Read 2362 times)
diarmuid
« on: September 13, 2004, 04:20:13 AM »
o.k. i've tried to crack this on my own but i've not had much luck.  so here i am again, cap in hand.
using the ssget function in a lisp routine i want to select dimensions by their individual dimscale.
below is similar to what i'm looking for, but instead i want to select dimensions by particular dimscales.
(setq ssleader (ssget "x" ' ((0 . "leader"))))
   (command "-layer" "make" "leader" "c" "2" "" "")
   (setq sslayer (getvar "clayer"))
   (command "_change" ssleader "" "properties" "layer" sslayer "")
from what i gather from the tutoring i'm getting from various web sites this is kinda the limit of my lisping.
any help would be greatly appreciated.
Regards
Diarmuid
*MST* changed the Subject of this thread
If you want to win something run the 100m, if you want to experience something run a marathon
« Reply #1 on: September 13, 2004, 06:40:32 AM »
The dimscale for the leader is contained in it's xdata. I'm not sure you can even filter for that so I used the activex approach.
(setq dscale (getreal "\nEnter DIMSCALE to filter: "))
; create a selection set of all the leaders in the dwg
(setq ss (ssget "_X" ' ((0 . "LEADER")))
 cntr 0
; iterate through each entity in the selection set
; converting it to a vla-object
(repeat (sslength ss)
  ; convert entity to object for activex use
  (setq obj
(vlax-ename->vla-object
 (ssname ss cntr)
  ; get the scalefactor of the object for comparison
  (setq dsf (vla-get-scalefactor obj))
  ; if the objects dimscale matches that entered by the user
  ; then change the objects layer to 'leader'
  (if (= dsf dscale)
 (vlax-put-property obj 'Layer "leader")
 (vlax-release-object obj)
  (setq cntr (1+ cntr))
  ); repeat
(setq ss nil)
diarmuid
« Reply #2 on: September 13, 2004, 07:36:29 AM »
thanks for the help Mark.
