Author Topic: Project-Auditing dwgs to a CAD Standard  (Read 31451 times)
Glenn R
Re: Project-Auditing dwgs to a CAD Standard
« Reply #15 on: July 22, 2008, 10:31:09 AM »
Up to the group - in my mind, if we're making a separate program we may as well do the lot, but that's just my opinion...
David Hall
  • Automatic Duh Generator
« Reply #16 on: July 22, 2008, 10:33:21 AM »
This is what I had in mind for the layer part.  Kerry B is the author of the first part, and I ahcked together the second
<?xml version="1.0" encoding="utf-8"?>
<LayerData>
  <Layer>
    <Description>Outlines 0.90mm</Description>
    <LayerName>ST90</LayerName>
    <Color>5</Color>
    <LineType>Hidden</LineType>
    <Alias>ST90</Alias>
  </Layer>
  <Layer>
    <LayerName>ST70</LayerName>
    <Description>Outlines 0.70mm</Description>
    <Color>3</Color>
    <LineType>Hidden2</LineType>
    <Alias>ST70</Alias>
  </Layer>
<?xml version="1.0" standalone="yes"?>
<NewDataSet>
  <Layers>
    <LayerName>0</LayerName>
    <Freeze>False</Freeze>
    <LayerOn>True</LayerOn>
    <Locked>False</Locked>
    <LineType>Continuous</LineType>
    <Color>7</Color>
  </Layers>
  <Layers>
    <LayerName>Defpoints</LayerName>
    <Color>7</Color>
  </Layers>
My thoughts were to check what layers were created, turned on and color and frozen.  We always seem to get dwgs back where the layers colors have been changed, things are frozen at random it seems.  Which is always very easy to clean up, I just run my setup program which recreates all the layers w/ correct settings.
« Last Edit: July 22, 2008, 10:37:58 AM by CmdrDuh »
Glenn R
« Reply #17 on: July 22, 2008, 10:50:25 AM »
OK, if we're going to be using DWS's, there wouldn't be any need for Layer definitions in XML as the layers would be directly in the DWS file...correct? Agree or disagree?
Glenn R
« Reply #18 on: July 22, 2008, 10:52:26 AM »
So do we have the list of what we want to check finished?
Probably not, but we'll forge ahead anyway. I don't see any problem with revising the program to cater for new conditions later on...
David Hall
« Reply #19 on: July 22, 2008, 10:55:42 AM »
I was thinking of putting everything in the XML file.  Thinking that each of us would have  a XML file with our perticular settings
David Hall
« Reply #20 on: July 22, 2008, 10:57:36 AM »
I totally agree we wouldn't need to put the layer info in the XML file.  Now the big question for me is how do we use a DWS file?  do we open it just like a dwg abd read the settings into memory and compare from there?
Glenn R
« Reply #21 on: July 22, 2008, 11:00:39 AM »
Essentially yes. You can see how I'm opening a dwg in memory in the code (readdwg), so, thinking out loud, we'll have some sort of class that has variables for the dws files and loads them in when necessary and you do the compare.
This has the added bonus as it's dealing with acad objects, not xml or anything else in this case....use the dws for what it is - a standards file.
David Hall
« Reply #22 on: July 22, 2008, 11:08:39 AM »
I completely agree, its just I have never done anything like this at all.  Not even in VBA, so you might end up explaining a ton of questions.  Just a forewarning
« Reply #23 on: July 22, 2008, 11:09:57 AM »
Sounds like fun.  I'm willing to help when/where I can, as I just got back from vacation, and some work has piled up waiting for me.
Glenn R
« Reply #24 on: July 22, 2008, 11:14:00 AM »
Well aware of that - no probs.
Glenn R
« Reply #25 on: July 22, 2008, 11:14:39 AM »
Ah...another victim...err volunteer. Good to see you back Tim.
Spike Wilbury
« Reply #26 on: July 22, 2008, 11:15:42 AM »
I been also busy, but I can bring the munchies, sodas, tacos, cerveza (beer), goodies, chilaquiles, tostadas, burritos, menudo, etc...  :mrgreen:
« Reply #27 on: July 22, 2008, 11:16:20 AM »
Thanks Glenn.... uh I think.
Glenn R
« Reply #28 on: July 22, 2008, 11:17:52 AM »
 :evil:
Glenn R
« Reply #29 on: July 22, 2008, 11:18:28 AM »
Good to hear Luis.
