Author Topic: Extracting XREF strings after the "|"  (Read 3204 times)
CADaver
« on: September 11, 2004, 06:01:13 PM »
Is there a nifty VLA or (GET-sumptin) or something that will extract block names and layer names as a string without the xref name itself??
FROM
MainRack|W14X43
to
W14x43
« Reply #1 on: September 11, 2004, 06:20:18 PM »
Something like this ??
(setq xx "MainRack|W14X43")
(if (setq index (vl-string-search "|" xx))
 (setq
   prefix (substr xx 1 index)
   suffix (substr xx (+ 2 index))
« Reply #2 on: September 11, 2004, 06:24:30 PM »
Sure, here ya go....
Usage: (setq str "MainRack|W14X43")
           (setq newstr (strip2bar str))
(defun strip2bar (str / pos)
  (setq pos (vl-string-search "|" str))
  (if (not pos) (setq pos -1));set pos incase "|" not found
  ;increment pos by 2, 1 for 0 vs 1 based index, 1 for next character
  (substr str (+ pos 2))
« Reply #3 on: September 11, 2004, 06:26:47 PM »
Arghhh! Beat out by Kerry.....no one's even here on Saturday/Sunday and I still get beat by a few minutes...... :/
« Reply #4 on: September 11, 2004, 06:34:00 PM »
Dont feel bad Jeff.  I beat myself all the time.
Oops, too much information ??
Ron Heigh
« Reply #5 on: September 11, 2004, 06:51:07 PM »
CADaver
« Reply #6 on: September 11, 2004, 07:28:15 PM »
Arrrrggghhh...  you won't believe how many times I went through the book and help files looking for vl-string-search and missed it every time.
Someday when I learn some of this lispy stuff, I might actually be useful.
Thanks a load guys, appreciate the help.
SPDCad
« Reply #7 on: September 11, 2004, 09:52:12 PM »
If you modify Jeff's code to the following you can search and extract any string. May come in handy when stripping the layer names in bound drawings.
(defun stripstr (str itm/ pos)
  (setq pos (vl-string-search itm str))
  (if (not pos) (setq pos -1));set pos incase item looking for not found not found
 enjoy! :)
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
