(Dan, is that you on the avatar?...)
es muy bueno
Quote from: le on August 05, 2008, 10:23:40 AM(Dan, is that you on the avatar?...)No that’s Ted Cassidy (AKA Lurch) as “RUK” in "Star Trek, What Are Little Girls Made Of?" (1966)is that you in yours?
That old guy is me.
Quote from: Daniel on August 05, 2008, 10:20:45 AMes muy bueno Good!!!, does not crash and works just on rectangular faces solids... or cubes ones
Quote from: le on August 05, 2008, 10:34:40 AMThat old guy is me. He's lying. That's Wolfgang Puck.
Quote from: le on August 05, 2008, 10:33:27 AMQuote from: Daniel on August 05, 2008, 10:20:45 AMes muy bueno Good!!!, does not crash and works just on rectangular faces solids... or cubes onesIt will process any solid that has at least two edges that are perpendicular, still working on Mick’s idea
Anyone have seen this:http://www.geo.informatik.uni-bonn.de/software/geotoolkit/intro.htm
Try this one Luis, this is a classic case of when the wrong edge could give invalid results.Note: the length should be perp the the I beam section.
