Author Topic: math formula  (Read 12645 times)
math formula
« on: September 26, 2003, 02:40:55 PM »
Mathematically speaking, does anyone know of a formula to do this:
given the number 502,345 -- I want in return 502,000
given the number 1,345,899  -- I want 1,346,000
given the number 18,373 -- I want 18,000
given the number 5389 -- I want 5000
given the number 130  -- I want 100
smadsen
math formula
« Reply #1 on: September 26, 2003, 03:03:40 PM »
Not a formula .. and a bit crude, but will this do?
(defun round (a / b)
  (cond ((>= a (setq b 1000.0)))
        ((>= a (setq b 100.0)))
        ((>= a (setq b 10.0)))
        ((< a 99) (setq b 1.0))
  (* (fix (/ a b)) b)
math formula
« Reply #2 on: September 26, 2003, 03:16:57 PM »
Perfect, thanks Stig.
daron
math formula
« Reply #3 on: September 26, 2003, 03:17:41 PM »
The only problem I see with it, is that it rounds it down, not up.
smadsen
math formula
« Reply #4 on: September 26, 2003, 03:33:06 PM »
Duh! Didn't see that .. thanks Daron.
Even cruder (bet it can be shortened some):
  (if (>= (- (abs (setq a (/ a b))) (fix (abs a))) 0.5)
    (cond ((minusp a) (setq a (1- a)))
          (T (setq a (1+ a))))
    a
  (* (fix a) b)
math formula
« Reply #5 on: September 26, 2003, 03:47:39 PM »
Stig, How did you get here?
Mark, Now we are sittin' at the cool table!
*Se7en does the "Saweeet Stig is here!" dance!*
smadsen
math formula
« Reply #6 on: September 26, 2003, 03:53:35 PM »
Well, if ya don't get an invite ya just gotta crash in, right?  :)
Followed Daron's link in the "previously frozen layer" thread on vbdesign.
Cool forum, by the way. Nice to see some people are still fond of AutoLISP :)
Should one register here?
math formula
« Reply #7 on: September 26, 2003, 03:53:37 PM »
sounds like a challenge to me <g>
math formula
« Reply #8 on: September 26, 2003, 03:57:00 PM »
Quote from: smadsen
...Should one register here?
Ooo yes please.
math formula
« Reply #9 on: September 26, 2003, 03:58:21 PM »
(- 8523 (rem 8523.00 1000))
something to think about..........
smadsen_000
math formula
« Reply #10 on: September 26, 2003, 04:04:19 PM »
Thanks Se7en .. will do!
Yup, REM will do, too. I bet that code could be shortened to a couple of lines once someone's head's been wrapped around it (mine doesn't fit today).
math formula
« Reply #11 on: September 27, 2003, 07:16:45 AM »
how about this?
(defun rndx (x)
    ((>= x 1000) (* (atof (rtos (/ x 1000.0) 2 0)) 1000))
    ((>= x 100) (* (atof (rtos (/ x 100.0) 2 0)) 100))
    ((< x 100) (* (atof (rtos (/ x 10.0) 2 0)) 10))
daron
math formula
« Reply #12 on: September 27, 2003, 03:43:11 PM »
I want to invite everybody, but not sure about ethical limits. I get the feeling some boards don't like other boards coming in and posting a different site all over theirs. I figured by just linking a possible soultion to this site IS an invite for all who select the link to look around and hopefully register and become an active board member. :D  BTW Stig, Welcome.
SMadsen
math formula
« Reply #13 on: September 27, 2003, 06:37:19 PM »
Daron, thank you.
Mark, interesting solution using string conversion. Using your idea, here's one that returns roundup to nearest ones, tens, hundreds etc..
(defun roundit (a)
  (setq b 1.0)
  (repeat (1- (strlen (rtos a 2 0)))(setq b (* b 10.0)))
  (* (atof (rtos (/ a b) 2 0)) b)
^Doesn't accept negative numbers though!
math formula
« Reply #14 on: September 27, 2003, 07:33:18 PM »
This is why I want to round off to the nearest number.
http://theswamp.org/mark.lisp/files/ModelSpace-Grid/
Thanks for the help Stig.
