Author Topic: Viewport, code 90  (Read 3704 times)
Patrick_35
Viewport, code 90
« on: July 15, 2008, 11:38:25 AM »
Hello
Do you know correspondence vlisp a viewport for code dxf 90, bit 131072 (without use vla-display...)
Re: Viewport, code 90
« Reply #1 on: July 15, 2008, 11:45:37 AM »
If you mean you'd like to change it via (entmod) and not ActiveX, you can't. (Entmod) does not work with Viewports, so you must either use a Command call or (vla-display VP :vlax-false)
Patrick_35
« Reply #2 on: July 15, 2008, 02:27:44 PM »
Thank you for your reply.
I know, it's just to see if a viewport is active or not, which is the code dxf 90.
I found the property ViewPortOn, but it only works if the layout on which the viewport was activated
« Reply #3 on: July 15, 2008, 03:23:46 PM »
Patrick_35
« Reply #4 on: July 16, 2008, 02:57:56 AM »
Thanks ronjonp
That's exactly it, except that I seek to do the same thing in vlisp.
I am almost, except for this bit in dxf 90. It is perhaps impossible.
« Reply #5 on: July 16, 2008, 11:37:31 AM »
Try this:
;;  CAB 07/16/2008 TheSwamp.org
;;  Return a list of Tab names & viewport object names
;;  If on? is true return only viewports that are ON
;;  else return ALL viewports
;;  Ignore Model Space
(defun view (on? / doc layout obj vp-list first-vp result)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for layout (vla-get-layouts doc)
    (setq vp-list nil)
    (if (/= (vla-get-name layout) "Model")
        (setq first-vp t) ; ignore the layout vp
        (vlax-for obj (vla-get-block layout)
          (if (and (eq (vla-get-objectname obj) "AcDbViewport")
                   (or (not on?) (eq (vla-get-ViewportOn obj) :vlax-true))
            (if first-vp
              (setq first-vp nil)
              (setq vp-list (cons obj vp-list))
        (and vp-list
             (setq result (cons (list (vla-get-name layout) vp-list) result))
  result
(defun c:test(/ lst)
  (setq lst (view t))
  (mapcar 'print lst)
Patrick_35
« Reply #6 on: July 16, 2008, 12:00:54 PM »
Thanks cab
But ViewportOn only works if the layout on which the viewport has already been activated at least once.
« Reply #7 on: July 16, 2008, 12:17:55 PM »
Testing with ACAD2000 it works fine in a newly opened drawing, no layouts active.
DWG opened in Model Space & the test routine ran fine, ignoring the Not On viewports.
Patrick_35
« Reply #8 on: July 16, 2008, 02:45:45 PM »
Thanks, but I try it in paperspace with A2005, and it's don't work
« Reply #9 on: July 16, 2008, 02:57:32 PM »
I just tried in the ACAD2004 and no go. :-(
Must neet to refresh the layouts before the variables are set properly.
« Reply #10 on: July 16, 2008, 07:15:55 PM »
Works but not what you wanted.
    (setq vp-list nil)
                   (or (not on?) (vla-put-activelayout doc layOUT)
            (if first-vp
              (setq first-vp nil)
        (and vp-list
  result
Patrick_35
« Reply #11 on: July 17, 2008, 02:55:56 AM »
Thanks cab
It is always interesting to see lisps other.  :-)
As is vlisp and that I would like to eliminate the viewport that are inactive, it me to use vlax-vla-object->ename. I liked to stay in vlisp  :-(
;;  Modified by Patrick_35   07/17/2008
(defun view (/ doc layout obj vp-list first-vp result)
    (setq vp-list nil)
        (setq first-vp nil) ; ignore the layout vp
   first-vp
   (zerop (logand (cdr (assoc 90 (entget (vlax-vla-object->ename obj)))) 131072))
            (setq first-vp T)
        (and vp-list
  result
« Reply #12 on: July 17, 2008, 08:47:07 AM »
Well we must work within the limits of ACAD 8-)
