Author Topic: How would I Explode an AutoCAD Table object?  (Read 3029 times)
Dan
« on: July 14, 2008, 03:01:46 PM »
How would I Explode an AutoCAD Table object?  I have created a sset of
tables, and wish to explode them into individual entities.
Any clues about how I should obtain this?
Thanks,
Dan
'code snippet
    Dim Ent As AcadEntity
    Dim oTable As AcadTable
    Dim oSet As AcadSelectionSet
    FilterType(0) = 0
    FilterData(0) = "ACAD_TABLE"
    Set oSet = ThisDrawing.SelectionSets.Add("DeleteTable")
    oSet.Select acSelectionSetAll, , , FilterType, FilterData
   For Each Ent In oSet
        Set oTable = Ent
        oTable.Explode 'obviously this will not work
    Next
fixo
Re: How would I Explode an AutoCAD Table object?
« Reply #1 on: July 14, 2008, 04:34:59 PM »
Hi Dan
Here is a dirty method but seems to be worked
for me
Option Explicit
Sub XplodeTest()
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
FilterType(0) = 0
          With ThisDrawing.SelectionSets
               While .Count > 0
                    .Item(0).Delete
               Wend
          Set oSet = .Add("DeleteTable")
          End With
Set oTable = Ent
'''oTable.Explode 'obviously this will not work
Dim hdl As String
hdl = oTable.Handle
Dim strcom As String
strcom = "EXPLODE" & Chr(32) & "(handent " & Chr(34) & hdl & Chr(34) & ")" & vbCr & vbCr & vbCr
ThisDrawing.SendCommand strcom
Next Ent
SendKeys "{ESC}"
DoEvents
End Sub
~'J'~
Dan
« Reply #2 on: July 14, 2008, 04:51:21 PM »
Thank you for the clever approach.  I personally hate to use sendcommand for anything, but I have yet to find a method through VBA. Thank you again.  This will work for my needs.
fixo
« Reply #3 on: July 14, 2008, 05:09:14 PM »
You're welcome
Cheers :)
~'J'~
