Author Topic: Coordinates of polyline segment  (Read 9995 times)
Gliderider
« on: July 14, 2008, 10:26:18 AM »
Is there a way (or what is the best way) to extract the coordinates of the endpoints of a polyline segment by selecting the polyline?
Re: Coordinates of polyline segment
« Reply #1 on: July 14, 2008, 10:34:14 AM »
There are many subroutine around. Here are two.
  ;;  get pline vertex list for LWPline only
  (defun get_pline_cor (elst)
    (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) elst))
   ;;  CAB 08/25/06 - revised 07.25.07
  ;;  get pline vertex list for any
   (defun getcoords (ent / endp idx pt result)
    (setq idx 0
          endp (vlax-curve-getEndParam ent))
    (while (< (setq idx (1+ idx)) endp)
      (setq pt (vlax-curve-getpointatparam ent idx))
      (setq result (cons pt result))
    (reverse (cons (vlax-curve-getendpoint ent) result))
« Reply #2 on: July 14, 2008, 10:35:34 AM »
Do you need help with the entire lisp or is this enough?
Gliderider
« Reply #3 on: July 14, 2008, 11:16:26 AM »
Thanks CAB, I appreciate your help again...
At the risk of showing my ignorance, I guess I need more help; apparently it's not as simple as I hoped. Using your first subroutine, I figured how get a list of all the coordinates of the polyline, but how could I get a list of just the endpoints of the segment of the polyline I select? Is there a way to determine between which 2 vertices I've picked?
« Reply #4 on: July 14, 2008, 11:33:35 AM »
This should do what you want:
(defun rjp-getadjacentplinevertices (ent pt / i p1 p2)
  (if (= (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
      (setq i  (fix (vlax-curve-getParamAtPoint
      ent
      (vlax-curve-getClosestPointTo ent pt)
    p1 (vlax-curve-getPointAtParam ent i)
    p2 (vlax-curve-getPointAtParam ent (1+ i))
      (list p1 p2)
To use:
(setq ent (entsel)
      pt  (cadr ent)
      ent (car ent)
(rjp-getadjacentplinevertices ent pt)
Gliderider
« Reply #5 on: July 14, 2008, 11:48:21 AM »
Thanks all, that worked great ronjonp. Now I've got some dissecting to do.
Thanks again...
« Reply #6 on: July 14, 2008, 12:11:27 PM »
Nice example Ron. 8-)
« Reply #7 on: July 14, 2008, 12:37:04 PM »
« Reply #8 on: July 14, 2008, 12:37:20 PM »
Thanks again...
Glad to help.
taner
« Reply #9 on: July 15, 2008, 01:06:32 AM »
Maybe we should use it like this:
(setq ent (entsel)
      pt  (osnap(cadr ent)"nea")
      ent (car ent)
      ent
      (list p1 p2)
To use:
(setq ent (entsel)
      pt  (cadr ent)
      ent (car ent)
gile
  • Marseille, France
« Reply #10 on: July 15, 2008, 05:59:59 AM »
(setq ent (entsel)
      ent (car ent)
As far as I tested, the way to get a point on the polyline have  to be different according to polyline type (lw, 2d or 3d) if the polyline plane is not parallel to WCS XY plane.
(setq pt (trans (osnap (cadr ent) "_nea") 1 0))Works fine with lwpolyline and 3d polylines, but may returns a wrong point with a 2d polyline (fited or splined polyline)
(vlax-curve-getClosestPointToProjection
  (car ent)
  (trans (cadr ent) 1 0)
  (mapcar '-
  (trans (getvar "VIEWDIR") 1 0)
  (trans '(0 0 0) 1 0)
Works with 2d and lwpolyline, but may returns a wrong point with a 3d polyline.
prexem
« Reply #11 on: July 19, 2008, 06:33:39 PM »
Try this, with vla-objects:
(setq e     (car (entsel "\nselect pline:"))
vla-e (vlax-ename->vla-object e)
vertexs     (vlax-get vla-e 'coordinates)
8-)
« Reply #12 on: July 20, 2008, 12:12:53 AM »
8-)
Welcome to TheSwamp prexem.
You misunderstood the request, he said "coordinates of a polyline segment "
which is two points only and not ALL the vertex points.
prexem
« Reply #13 on: July 21, 2008, 08:34:15 PM »
;|Hello CAB:
I am a neophyte in autolisp ......
To obtain coordinates of every segment, showing a list:
(defun coords-segments (/     errant   *error*     e     vla-e v
c     cant  xp   c1 yp    zp    p   lp
rlp   cantp p1   p2 d
  (defun errcs (m) (prompt "\n*end of command*"))
  (setq errant *error*
*error* errcs
  (setq e
(car
   (entsel
     "\nselect a pline:"
    (or
      (equal (cdr (assoc 0 (entget e))) "POLYLINE")
      (equal (cdr (assoc 0 (entget e))) "LWPOLYLINE")
       (setq vla-e (vlax-ename->vla-object e)
     v    (vlax-get vla-e 'coordinates)
       (setq c 0)
       (setq cant (/ (length v) 2))
       (repeat cant
(setq xp (nth c v)
       c1 (1+ c)
       yp (nth c1 v)
       zp 0.0
       p  (list xp yp zp)
       lp (cons p lp)
       c  (1+ c1)
       (setq rlp (reverse lp))
       (setq cantp (length rlp))
       (setq c 0)
       (repeat cantp
(setq p1 (nth c rlp))
(setq c1 (1+ c))
(setq p2 (nth c1 rlp))
(setq d (distance p1 p2))
(setq c (1+ c))
(princ "\nsegment ")
(princ c1)
(princ ": ")
(princ d)
(princ "\nstart of segment ")
(princ c1)
(princ ": ")
(princ p1)
(princ "\nend of segment ")
(princ c1)
(princ ": ")
(princ p2)
     (princ "\n*THIS OBJECT IS NOT A PLINE*")
  (setq *error* errant)
(defun c:cs () (coords-segments) (princ))
;|Or show coordinates of only a segment:|;
(defun coords-1segment (/     errant   *error*     e     ns   vla-e
v     c     cant  xp c1    yp    zp   p
lp    rlp   cantp p1 p2    duo   lstduo
lst   duons
*error* errcs
  (setq e
(car
   (entsel
     "\nselect a pline:"
  (setq ns (getint "\nnumber of segment: "))
    (or
       (setq c 0)
       (repeat cant
(setq xp (nth c v)
       c1 (1+ c)
       yp (nth c1 v)
       zp 0.0
       p  (list xp yp zp)
       lp (cons p lp)
       c  (1+ c1)
       (setq c 0)
       (repeat cantp
(setq c1 (1+ c))
(setq duo (list p1 p2))
(setq lstduo (cons duo lstduo))
(setq c (1+ c))
       (setq lst (reverse lstduo))
       (setq duons (nth (1- ns) lst))
       (princ "\ncoordinates of segment: ")
       (princ duons)
(defun c:c1s () (coords-1segment) (princ))
« Last Edit: July 21, 2008, 09:02:04 PM by prexem »
« Reply #14 on: July 21, 2008, 09:12:57 PM »
prexem
Both of these sub functions return the list of vertex:
http://www.theswamp.org/index.php?topic=23951.msg289954#msg289954
This routine returns the list of vertex for a pline segment selected.
http://www.theswamp.org/index.php?topic=23951.msg289975#msg289975
Give them a try.
