Author Topic: Aecc Points List  (Read 3970 times)
surveyor_randy
Aecc Points List
« on: July 09, 2008, 05:18:46 PM »
I am trying to write a program that will dump a points list in PNEZD (CSV) format into a text file and then display the text file.  The program works but the points aren't in numerical order.  I simply did a "for each Point in Points" loop.  Is there an easy way to sort these?  Or am I going to have to resort to using a list.  And if I did use the list, what would be the simplest way to do this.  Dump all of the points into an array and use the array index matched with the point number in my key-value pair?  I'm open to suggestions.  Thanks in advance!
Imports System
Imports Autodesk
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports AcadNET = Autodesk.AutoCAD
Imports AcadCOM = Autodesk.AutoCAD.Interop
Imports AcadNETApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports AeccLandLib = Autodesk.AECC.Interop.Land
Imports AeccUiLandLib = Autodesk.AECC.Interop.UiLand
Imports AecUIBase = Autodesk.AEC.Interop.UIBase
Namespace MyUtils
    Public Class Commands
        Private oAcadApp As AcadCOM.AcadApplication
        Private oAeccApp As AeccUiLandLib.IAeccApplication
        Private oAeccDoc As AeccUiLandLib.IAeccDocument
        Private oAeccDb As AeccLandLib.IAeccDatabase
        <CommandMethod("PTLIST")> _
    Public Sub DisplayPointList()
            Dim ed As Editor = AcadNETApp.DocumentManager.MdiActiveDocument.Editor
            oAcadApp = AcadNETApp.AcadApplication
            oAeccApp = oAcadApp.GetInterfaceObject("AeccXUiLand.AeccApplication.5.0")
            oAeccDoc = oAeccApp.ActiveDocument
            oAeccDb = oAeccApp.ActiveDocument.Database
            Try
                Dim oPoints As AeccLandLib.AeccPoints
                Dim oPoint As AeccLandLib.AeccPoint
                Dim oToFile As System.IO.TextWriter
                oToFile = System.IO.File.CreateText("C:\points.txt")
                oPoints = oAeccDb.Points
                For Each oPoint In oPoints
                    If oPoint.Elevation < -999999 Then oPoint.Elevation = "0"
                    oToFile.WriteLine(oPoint.Number & "," & oPoint.Northing & "," & oPoint.Easting & "," & oPoint.Elevation & "," & oPoint.RawDescription & "")
                Next
                oToFile.Flush()
                oToFile.Close()
                oAcadApp = Nothing
                oAeccApp = Nothing
                oAeccDoc = Nothing
                oAeccDb = Nothing
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage("Error: ", ex.Message & vbCrLf)
            End Try
            Process.Start("notepad.exe", "C:\points.txt")
        End Sub
    End Class
End Namespace
Re: Aecc Points List
« Reply #1 on: July 09, 2008, 05:45:30 PM »
Do you know about the ExportPoints method of the Points collection? In my limited testing, this exports in numerical order.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: July 09, 2008, 06:12:15 PM »
You ought to be able to dump your objects to a list like you mentioned, then sort the list using a comparer function.
Pseudo code:
  public static int oPointCompare(AeccPoint oPointA, AeccPoint oPointB)
      return oPointA.Number.CompareTo(oPointB.Number);
      List<AeccPoint> listOPoints = new List<AeccPoint>(AeccLandLib.AeccPoints);
      listOPoints.Sort(oPointCompare);
« Reply #3 on: July 09, 2008, 06:39:54 PM »
Yep, I'm sure it does the sorting for you....
    <CommandMethod("TestMe")> _
     Public Sub TestMe()
        Dim m_AcadApp As AcadApplication
        Try
            m_AcadApp = Application.AcadApplication()
            Dim m_oAeccApp As New AeccApplication()
            m_oAeccApp.Init(m_AcadApp)
            Dim m_oAeccDoc As AeccDocument = m_oAeccApp.ActiveDocument
            Dim oPoints As AeccPoints = m_oAeccDoc.Points
            Dim oPtOpts As New AeccPointExportOptions()
            ' use the defaults....
            oPoints.ExportPoints("c:\points.txt", "PNEZD (comma delimited)", oPtOpts)
        Catch
            MsgBox(Err.Description() & Err.Number)
        End Try
    End Sub
surveyor_randy
« Reply #4 on: July 10, 2008, 07:28:00 AM »
Thanks for the help guys!  I think that I am going to look into using the exportpoints method that Jeff suggested.  Since I am so new to .NET programing, can anyone comment on anything that looks unorthodox?
Glenn R
« Reply #5 on: July 10, 2008, 07:56:48 AM »
Yep - VB.NET  :-D
surveyor_randy
« Reply #6 on: July 11, 2008, 07:22:43 AM »
Yep - VB.NET  :-D
smart ass!  :-)
