Author Topic: Want to Learn OpenDCL  (Read 8819 times)
GDF
« on: July 09, 2008, 02:23:14 PM »
James
Gary, would you like to learn OpenDCL?  Would you like me to convert this or maybe a simpler project (easier for you to follow) to an OpenDCL form?
Just let me know - I'll be glad to help ...
Yes, thanks. Here is a simple routine to start off with. I have thrown in more code than necessary. Not enough time now to sift through it.
Command name is WEB
    Place the following files in your AutoCAD Support File Search Path:
        ARCH_WEB.vlx compiled routine
        ARCH_WEB.arch editable text file
        ARCH_WEB.lisp editable text file
        ARCH_WEB.misc editable text file
Thanks again James
Gary
jbuzbee
Re: Want to Learn OpenDCL
« Reply #1 on: July 09, 2008, 02:43:37 PM »
Well let me have a look . . .
James Buzbee
Windows 8
GDF
« Reply #2 on: July 09, 2008, 02:47:47 PM »
James
If not the one I posted, any simple routine will do.
« Reply #3 on: July 09, 2008, 04:15:27 PM »
Why dont we start off with a Hello world application?
A hello world app that that will report env vars or something?
jbuzbee
« Reply #4 on: July 09, 2008, 04:23:57 PM »
Ok, check this out -
This is the only file needed (ARCH_OPENDCL.lsp) besides the OpenDCL.arx and the URL list files.
In the zip file there are three files:
ARCH.odcl - this is the file the openDCL editor uses to create and edit forms and controls.  Use the OpenDCL editor on the file.
ARCH.lsp - this file is generated by the OpenDCL editor to create a compiled version of the ARCH.odcl file.  This is read directly into AutoCAD.  The contents of the file are copied into the ARCH_OPENDCL file and loaded when the rest of the lisp is loaded.
ARCH_OPENDCL.lspp is the AutoLISP file that runs the whole show. Let me know if this easy enough to follow . . .
James Buzbee
Windows 8
GDF
« Reply #5 on: July 09, 2008, 04:47:27 PM »
James
Command: web
; error: no function definition: DCL_HIDEERRORMSGBOX
DCL_PROJECT_IMPORT
jbuzbee
« Reply #6 on: July 09, 2008, 05:02:27 PM »
Sorry - did you download the OpenDCL.arx and put it in AutoCAD's search path?
I'll attach it here . . . what version of UatoCAD are you using?
James Buzbee
Windows 8
GDF
« Reply #7 on: July 09, 2008, 05:10:22 PM »
Yes, I'm using OpenDCL17.arx and it is loaded. I'm using 2008 on windows xp
Command: web
; error: no function definition: DCL_PROJECT_IMPORT
Command:
jbuzbee
« Reply #8 on: July 09, 2008, 05:27:00 PM »
Sorry Gary - it's working here.
When you type in (arx) are you sure OpenDCL.17.arx is in the list??
James Buzbee
Windows 8
GDF
« Reply #9 on: July 09, 2008, 05:33:48 PM »
YEP, it's showing up
I am missing the sub routines called out in your lisp file.
(dcl_hideerrormsgbox)
(dcl_project_import...
jbuzbee
« Reply #10 on: July 09, 2008, 05:41:32 PM »
That's wiered - they're defined in the OpenDCL.arx.  Any function named "dcl_" is defined in that arx.
James Buzbee
Windows 8
GDF
« Reply #11 on: July 09, 2008, 05:49:46 PM »
I even used your copy of the arx file, and it is loaded. Double check it with appload and (arx)
It's there.
jbuzbee
« Reply #12 on: July 09, 2008, 08:35:32 PM »
This is why a rarely post stuff . . . sorry.
I guess this will be the last.
James Buzbee
Windows 8
« Reply #13 on: July 10, 2008, 08:29:16 AM »
Why wouldn't you post anything anymore? ...I dont understand; you dont like posting cause it didnt work right away? I cant tell you how many apps ive posted that didnt work (maybe a half a thousand).
« Reply #14 on: July 10, 2008, 09:05:07 AM »
Yea, programming is such an exact science. One little character out of place & whamo!
It can be very frustrating at times.
