Sorry for the delay, I've been out for dinner :whistle:
Actually my code works, I can fix the support path in each of the AutoCAD's installed for the different users in every computer in my office, and if needed I can move to another office we have not far away, just a few hours drive (one working day!).
Since the software that I develop is not made for commercial purposes I never have the need of creating a deployment, I just copy the dll's or the exe and register, if needed, activex's.
The best thing would be to create an installer like the ones I get in some third party programs (AutoTURN or Acroplot), in which you run the setup and get everything done: support path added to AutoCAD, toolbars, menus and everything else, but that's beyond my actual knowledge, I tried with VS 2005 creating a "Setup and Deployment" Project, but haven't found out how to add "C:\Documents and Settings\All Users\Dati applicazioni\..." directory to it. By the way I had chosen this one because it was present in Windows 2000 and Windows XP, so I didn't have to add that much of a support path to AutoCAD, I already knew where to look for my support files!
It seemed a good idea before Vista changed the naming of these directories (things I learned when it was to late).
Now, since I have to change distributing method to accomplish external collaborators requests, I thought that a simple "Setup and Deployment" and a modification to the "UserConfigurationManager" adding a support path was an acceptable solution, but after your replies Glenn
Secondly, ditch the 'userconfigurationmanager', because as I alluded to in one of those threads you quoted (I think) and Dan confirmed in this thread, it doesn't behave as expected and gives undesirable results.
I guess I might been seeking in some other direction.
Thanks for your time and attention, I just love this place!
If you have any other suggestion I should try exploring, just point at it and I'll follow.
René
P.S.
I have allways accomplished my duties in VB, but after a while swimming in TheSwamp, in trying to migrate myself to C#, it seems that all you guys in here find it better, even if uncle Bill says they're the same!
