Author Topic: Layer Creator Project  (Read 39262 times)
VovKa
  • Ukraine
Re: Layer Creator Project
« Reply #30 on: July 02, 2008, 04:34:49 PM »
chances for mistakes from the end user.
that's for sure, and that's why i use dbx
« Reply #31 on: July 02, 2008, 04:36:07 PM »
My wish was to keep the data file as easy to maintain as possible.
Using the example file "Framing Layer Data File" I posted, you can still use tab
as the separator.
Where do you see the errors creeping in with that format?
jbuzbee
« Reply #32 on: July 02, 2008, 04:37:12 PM »
Tim,
I don't have an image of the form, but I use Layer Filters defined in the Layer Data File to "sort" Layers in the Import Layer form.  And yes, ObjectDBX is very powerful: I have Forms to import Views and Blocks, I have a form that pulls all our ADT stuff, styles etc, from a main ADT Data Drawing where all our styles are defined. That drawing is the defined ADT Standards drawing - so as I update / edit styles I use this tool to update a Project - and of course the next time a user starts drawing a wall (even if it's note already defined in the active drawing)they have the latest style definition instantly via ObjectDBX.
The nice thing about this type of program - management theory is A: the template drawing doesn't necessarily have to contain all Layers (Blocks, Views, ADT Styles, etc.) B: When used with AutoCAD's Standards tool it makes managing Office Standards a breeze, and C: the user decides what layers (s)he needs at any point in time - instead of inserting an entire drawing (one place I worked had over 700 standard layers!)
James Buzbee
Windows 8
« Reply #33 on: July 02, 2008, 04:41:08 PM »
VovKa,
My thought when i was creating my layer creator was that a delimited file for my layers was a pain to maintain. So i made mine use the AutoCAD method (list of lists). ...Give this one a try:
http://www.theswamp.org/index.php?topic=23173.msg280776#msg280776
Load it up and just cancel the dialog box that will pop up.
Use the (save-layer-list-to-file) function to save a layer file you can look at. Then you can see what im talking about. The whole process fast and fairly clean.
« Reply #34 on: July 02, 2008, 04:42:50 PM »
as the separator.
1.) I dislike tabs in general so i disable them in my editor; i use spaces instead.
2.) A user in Notepad just hits the space bar instead of tab.
3.) A user uses two tabs instead of one.
« Reply #35 on: July 02, 2008, 04:43:42 PM »
now that is a good point!
VovKa
  • Ukraine
« Reply #36 on: July 02, 2008, 04:44:07 PM »
an old lady drafting all day long and expecting computer to be smart enough to read her thougts, will surely find a way to crash any application :)
maybe misspelling, maybe typing ":" instead of ";" somewhere in data file, end users are rather ingenious...
« Reply #37 on: July 02, 2008, 04:45:48 PM »
Tim,
My AutoLisp version was tested on 10,000 layers and took about 1 second. How long would it take for ODBX?
« Reply #38 on: July 02, 2008, 04:57:05 PM »
Won't correct layers.  I have a routine that will correct the layers to meet company standards if the don't.  You have to use code to do it, and I use ODBX.
Tim do you have a link to your latest routine?
Here you go Alan.
[ http://www.theswamp.org/index.php?topic=12845.msg156899#msg156899 ]
VovKa
  • Ukraine
« Reply #39 on: July 02, 2008, 04:57:31 PM »
45 seconds
« Reply #40 on: July 02, 2008, 04:58:27 PM »
ODBX or read from a text file to me is the same, just that a drawing you know has to have layers laid out correctly.  I don't use text files I only use drawings, and I have the drawings separated out to disciplines.
« Reply #41 on: July 02, 2008, 05:08:34 PM »
45 seconds?!?!  ...No way. I wrote that one because the previous one here (i didnt write it, it was before my time) took 3 seconds for 100 layers!?! *lol*
« Reply #42 on: July 02, 2008, 05:10:05 PM »
Will not overwrite, but will create if not there.  Worked on the test list except for some linetypes that I don't have, and that didn't stop the command from running.
Had to use one ActiveX call, as I don't know how else to get a linetype into the table without it or a 'command' call.
(defun c:Test (/ LtCol LtFileList File Opened Str tempStr LayPat tempList Dflt LayList PltStyList tempData tempName
    tempLt LtList Found tempPs)
    (defun GetPlotStyleList (/ tempName tempList)
        (foreach i (dictsearch (namedobjdict) "ACAD_PLOTSTYLENAME")
                ((equal (car i) 3)
                    (setq tempName (cdr i))
                ((equal (car i) 350)
                    (setq tempList (cons (cons tempName (cdr i)) tempList))
        tempList
    (defun ReadLinetypeFile (Path / Opened tempStr tempList)
        (setq Opened (open Path "r"))
        (while (setq tempStr (read-line Opened))
            (if (= (substr tempStr 1 1) "*")
                (setq tempList
                    (cons
                        (strcase (car (StrParse (substr tempStr 2) ",")))
                        tempList
        (close Opened)
        tempList
    (setq LtCol (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-Acad-Object))))
    (setq LtFileList
        (list
            (if (equal (getvar 'Measurement) 0)
                "acad.lin"
                "acadiso.lin"
            (setq File (getfiled "Select layer definition file." "" "lay" 4))
            (setq Opened (open File "r"))
                (while (setq Str (read-line Opened))
                    (setq tempStr (substr Str 1 2))
                        ((= tempStr "*-")
                            (setq LtFileList (cons (substr Str 4) LtFileList))
                        ((= tempStr "*/")
                            (setq LayPat (StrParse (substr Str 4) " "))
                            (foreach i LayPat
                                (if (> (strlen i) 0)
                                    (setq tempList (cons i tempList))
                            (setq LayPat (mapcar 'strcase (reverse tempList)))
                        ((= tempStr "*+")
                            (setq Dflt (mapcar 'RemoveSpace (StrParse (substr Str 4) (car LayPat))))
                                (/= (substr tempStr 1 1) "*")
                                (/= tempStr "")
                                (/= (substr tempStr 1 1) " ")
                            (setq LayList
                                (cons
                                    (mapcar 'RemoveSpace (StrParse Str (car LayPat)))
                                    LayList
                (close Opened)
                LayList
            Dflt
            (setq LayPat (cdr LayPat))
            (setq ListLen (length LayPat))
            (setq PltStyList (GetPlotStyleList))
        (foreach i LayList
            (setq cnt 0)
            (setq tempData '((70 . 0)))
            (repeat ListLen
                (setq tempProp (nth cnt LayPat))
                (setq tempValue (nth cnt i))
                    ((= tempProp "NAME")
                        (setq tempData
                            (cons
                                (cons 2 (setq tempName tempValue))
                                tempData
                    ((= tempProp "PLOTSTYLENAME")
                        (setq tempData
                            (cons
                                (if (setq tempPs (assoc tempValue PltStyList))
                                    (cons 390 (cdr (assoc tempValue PltStyList)))
                                    (cons 390 (cdr (assoc "Normal" PltStyList)))
                                tempData
                    ((= tempProp "COLOR")
                        (setq tempData
                            (if (setq tempList (assoc 62 tempData))
                                (subst
                                    (cons
                                        62
                                        (if (< (cdr tempList) 0)
                                            (* -1 tempValue)
                                            tempValue
                                    tempList
                                    tempData
                                (cons
                                    (cons 62 (atoi tempValue))
                                    tempData
                    ((= tempProp "LINETYPE")
                        (setq tempData
                            (cons
                                (cons 6 (setq tempLt (strcase tempValue)))
                                tempData
                    ((= tempProp "FREEZE")
                        (if (= tempValue "FREEZE")
                            (setq tempData
                                (if (setq tempList (assoc 70 tempData))
                                    (subst
                                        (cons
                                            70
                                            (1+ (cdr tempList))
                                        tempList
                                        tempData
                                    (cons
                                        (cons 70 1)
                                        tempData
                    ((= tempProp "LOCK")
                        (if (= tempValue "LOCK")
                            (setq tempData
                                    (subst
                                        (cons
                                            70
                                            (+ (cdr tempList) 4)
                                        tempList
                                        tempData
                                    (cons
                                        (cons 70 4)
                                        tempData
                    ((= tempProp "LAYERON")
                        (if (= tempValue "OFF")
                            (setq tempData
                                    (subst
                                        (cons
                                            62
                                            (* -1 (cdr tempList))
                                        tempList
                                        tempData
                                    (cons
                                        (cons 62 -7)
                                        tempData
                (setq cnt (1+ cnt))
            (if (not (tblsearch "LType" tempLt))
                (foreach i LtFileList
                    (setq Found nil)
                    (if (not Found)
                            (if (not (assoc i LtList))
                                (setq LtList
                                    (cons
                                        (cons i (ReadLinetypeFile (findfile i)))
                                        LtList
                            (setq tempList (assoc i LtList))
                            (if (member tempLt tempList)
                                    (vlax-invoke LtCol 'Load tempLt i)
                                    (setq Found T)
                (not
                    (entmake
                        (append
                                (0 . "LAYER")
                                (100 . "AcDbSymbolTableRecord")
                                (100 . "AcDbLayerTableRecord")
                            (reverse tempData)
                (prompt (strcat "\n Could not make layer: " tempName))
Edit:
Forgot to post the subs.
(defun RemoveSpace (String / cnt)
; Remove spaces from begining and end of string
(while (= (substr String 1 1) " ")
(setq String (substr String 2 (strlen String)))
(setq cnt (strlen String))
(while
(> cnt 0)
(= (substr String cnt 1) " ")
(setq cnt (1- cnt))
(substr String 1 cnt)
(defun StrParse (String Seperator / Pos1 Pos2 NewStrList)
  Seperator a string (making a list of stings) at a given
  string value
  ie: (StrParse "1,1,0" ",")
  returns: ("1" "1" "0")
  Written when I couldn't find it on the web
  By: Tim Willey 11/15/2004
(setq Pos2 1)
(while (setq Pos1 (vl-string-search Seperator String Pos1))
(if (= Pos2 1)
(setq NewStrList (cons (substr String Pos2 Pos1) NewStrList))
(setq NewStrList (cons (substr String Pos2 (- (1+ Pos1) Pos2)) NewStrList))
(setq Pos2 (1+ (+ (strlen Seperator) Pos1)))
(setq Pos1 (+ Pos1 (strlen Seperator)))
(reverse (setq NewStrList (cons (substr String Pos2) NewStrList)))
« Last Edit: July 02, 2008, 05:22:36 PM by T.Willey »
« Reply #43 on: July 02, 2008, 05:15:59 PM »
T.Willey,
How do you code up some of these larger lisps in so little time...You must type 1000 words per min!?
VovKa
  • Ukraine
« Reply #44 on: July 02, 2008, 05:19:19 PM »
my dbx loads 100 layers in tenths of a second, so not a problem for me :)
