I have been able to successfully import code that I did in VBA, into VB.net,
compile it to a .dll file using the commandmethod.
I have my import statements in there and with the nec. references (as far as I can see) set in .net
Now, I am trying to do the same thing with code that I did in VBA, using a .net form.
It says that it is building successfully but I have not had any luck with getting it to run correctly.
Does anyone have any suggestions or examples of using this techniques?
I am sure that I am doing something wrong but I believe this can be done.
If nec. I can post the code.
Thank you
Zep
