Author Topic: vba for attaching material(bmp,jpeg) to layer in autocad  (Read 9242 times)
shamsam1
« on: July 01, 2008, 09:02:59 AM »
Can anyone help me to code in vba for attaching material(bmp,jpeg) to layer in autocad  and render on click of a button.Its urgent.
David Hall
  • Automatic Duh Generator
Re: vba for attaching material(bmp,jpeg) to layer in autocad
« Reply #1 on: July 01, 2008, 10:05:13 AM »
what do you have so far?
zep6980
« Reply #2 on: July 01, 2008, 12:41:30 PM »
Hey Sham
I have done these things manually but never automated the process
I agree with CM, cna you show us what you've done so far?
Bob Wahr
« Reply #3 on: July 01, 2008, 02:11:38 PM »
Couldn't stay away, member formerly known as ML?
- EDIT -
removed first person reference by member request
- EDIT -
left first person reference out for now but regained at least some of the intent of my post
« Last Edit: July 02, 2008, 11:58:40 AM by Bob Wahr »
zep6980
« Reply #4 on: July 02, 2008, 04:42:47 PM »
And what was the intent Bob?
My intent is to advance my CAD skills and try to help others as much as I can.
I don't hang onto animosity.
In the future, please feel free to pvt me anytime,  as opposed to placing none CAD related matter (such as my first name) in the post.
Thank you
Zep
Bob Wahr
« Reply #5 on: July 03, 2008, 09:34:45 AM »
I wasn't aware that calling someone by name equaled animosity.  You can read that on whatever your next account is.
Glenn R
« Reply #6 on: July 03, 2008, 10:00:31 AM »
:lmao:
shamsam1
« Reply #7 on: August 07, 2008, 01:44:12 AM »
this is what i have it work fine in autcad2007 but in 2005 some problem
(defun c:pumat(/ Lst sSet mLst cMat sCnt lCnt mCnt eCnt)
  (setq Lst (list
          '("0" "Global")
'("Layer1" "Material 2")
        ); end list
            ); end setq
(if(setq sSet(ssget "_X" '((0 . "*SOLID"))))
    (setq sCnt 0 lCnt 0)
    (vlax-for mat (vla-get-Materials
              (vla-get-ActiveDocument
           (vlax-get-acad-object)))
      (setq mLst(cons(vla-get-Name mat)mLst))
      ); end vlax-for
    (foreach itm
        (mapcar 'vlax-ename->vla-object
          (vl-remove-if 'listp
            (mapcar 'cadr(ssnamex sSet))))
         (if(setq cMat
         (cadr
           (assoc
             (setq cLay(vla-get-Layer itm))Lst)))
      (if(member cMat mLst)
        (if(vl-catch-all-error-p
             (vl-catch-all-apply 'vla-put-Material
          (list itm cMat)))
          (setq lCnt(1+ lCnt))
          (setq sCnt(1+ sCnt))
          ); end if
        (if(not(member cMat mCnt))
         (setq mCnt(cons cMat mCnt))
          ); end if
        ); end if
      (if(not(member cLay eCnt))
        (setq eCnt(cons cLay eCnt))
        ); end if
          );end if
       ); end foreach
    (if(or(/= 0 lCnt)(/= 0(length mCnt))(/= 0(length eCnt)))
   (princ "\n========================= ERROR LIST =========================\n")
   (if(/= 0(length mCnt))
       (princ "\nFollowing materials missed in drawing: \n")
       (foreach mat mCnt
         (princ(strcat "\n " mat))
         ); end foreach
       (princ "\n")
       ); end progn
     ); end if
       (if(/= 0(length eCnt))
       (princ "\nSome solid layers missed in list: \n")
       (foreach lay eCnt
         (princ(strcat "\n " lay))
         ); end foreach
       (princ "\n")
       ); end progn
     ); end if
    (if(/= 0 lCnt)
      (princ(strcat "\n" (itoa lCnt) " were on locked layer!\n"))
     ); end if
   (princ "\n========================== END LIST ==========================\n")
   (textscr)
   ); end progn
      ); end if
         (princ(strcat "\n<<< Materials are appropriated for "
            (itoa sCnt) " of "
            (itoa(sslength sSet)) " solids >>>"))
    ); end progn
  (princ "\n<!> No Solids Found <!> ")
  ); end if
  ); end of c:pumat
jnieman
« Reply #8 on: August 07, 2008, 12:51:58 PM »
I take it you gave up on using vba :P
shamsam1
« Reply #9 on: August 07, 2008, 01:46:30 PM »
wel stil looking for vba version of the code. to attach material to layer for autcad2005 :mrgreen:
shamsam1
Re: vba/lisp for attaching material(bmp,jpeg) to layer in autocad2005/2006
« Reply #10 on: August 09, 2008, 02:05:38 AM »
Help me out guys to attach  material to layer in autocad2005/2006 with vba or lisp program..badly needed. :-)
jbuzbee
« Reply #11 on: August 11, 2008, 10:07:05 AM »
the Materials Collection was introduced when the render-er changed in 2007.
Materials in 2006 and earlier are defined by the old ACAD_RENDER ads program and are not accessible via activex - I don't know if there is even a command line version for attaching materials to a layer.
These are the only commands defined by the ACAD_RENDER arx:
c:3dsin, c:3dsin
    c:3dsout, c:3dsout
    c:background, c:background
    c:finish, c:finish
    c:fog, c:fog
    c:light, c:light
    c:lsedit, c:lsedit
    c:lslib, c:lslib
    c:lsnew, c:lsnew
    c:matlib, c:matlib
    c:render, c:render
    c:renderupdate, c:renderupdate
    c:rendscr, c:rendscr
    c:replay, c:replay
    c:rfileopt, c:rfileopt
    c:rmat, c:rmat
    c:rpref, c:rpref
    c:saveimg, c:saveimg
    c:scene, c:scene
    c:setuv, c:setuv
    c:showmat, c:showmat
    c:stats, c:stats
James Buzbee
Windows 8
shamsam1
« Reply #12 on: August 11, 2008, 11:28:55 AM »
thanks jab jbuzbee
at least some thing i got to start with ... :roll:..wiill experiment with it tomorrow
jbuzbee
« Reply #13 on: August 11, 2008, 11:50:43 AM »
here's another thought:
could you set up a standard material/layer drawing?  have the materials already attached to the layer.  then you could import the layers via objectdbx.  You could even use a naming convention or include the material in the description:
3d-wall-stucco-red . . . "sand finish stucco with red paint finish"
I've got an import layers routine in AutoLISP, but it requires OpenDCL (which is free) for the GUI:
OpenDCL
http://sourceforge.net/projects/opendcl/?abmode=1
James Buzbee
Windows 8
shamsam1
« Reply #14 on: August 11, 2008, 12:10:40 PM »
i have materail list and layer list ...so i just need to attach materiel to particular layer by using command which i am doing in 2007 as i pasted lisp the code above..same thing i need to do in 2005
