Author Topic: Can't erase objects?  (Read 2830 times)
vinnyg
« on: June 30, 2008, 09:45:13 AM »
Hi all,
I'm working with somebody else's cad file, trying to erase some objects (text) but won't
erase. Here's what list says about object:
       ACAD_PROXY_ENTITY  Layer: S-TXT-MISC
                            Space: Model space
                   Handle = 142
                   DXF name:         ACAD_PROXY_ENTITY_WRAPPER
                   Class name:       AcDbProxyEntityWrapper
                   Application name: ObjectDBX Classes
Any ideas why I can't erase it? Any suggestions how I can erase it?
thanks,
vinny
vinnyg
Re: Can't erase objects?
« Reply #1 on: June 30, 2008, 11:30:41 AM »
Well, I found out how to solve the problem. I changed the variable "proxyshow" to 0
There were a few leftover objects, but I was able to erase them. In case anyone has a
problem with these in the future.
vinny
vinnyg
« Reply #2 on: July 24, 2008, 10:19:21 AM »
UPDATE!
I tried to solve the same problem on another drawing using the same technique I used on the previous
drawing (last post) but it didn't work this time!?
vinny
« Reply #3 on: July 24, 2008, 10:49:22 AM »
how about posting a copy of that file for us to poke at?
vinnyg
« Reply #4 on: August 01, 2008, 09:38:24 AM »
OK, here's the file. When you open it you will see some partial entities that remained after I tried to delete the some main floor plan drawings.
thanks,
vinny
« Reply #5 on: August 01, 2008, 09:42:13 AM »
I can delete everything without issue
Bob Garner
« Reply #6 on: August 01, 2008, 10:31:10 AM »
Yeh, I was able to go in and erase anything and everything.
vinnyg
« Reply #7 on: August 01, 2008, 12:48:31 PM »
OK guys,
Explain this. When I tried to erase those objects in r14.....couldn't. Then I opened the drawing
in 2007 and they erased without problems. So what's going on? How come I could'nt erase them
in r14?
thanks for looking
vinny
« Reply #8 on: August 01, 2008, 01:20:20 PM »
I just erased them in R14. :?
vinnyg
« Reply #9 on: August 01, 2008, 03:47:56 PM »
Well now I'm really stomped. Opened the drawing in r14 again and couldn't pick, list or erase
the objects in question. Still in the dark.
vinny
craigr
« Reply #10 on: August 05, 2008, 07:05:50 AM »
I just downloaded your file and I was able to erase everything in 2008LT.
Now if THIS wimpy prg is able to do it..... :)
Just throwing this out there - What about an Install problem? Maybe something got discombobulated.
craigr
« Reply #11 on: August 05, 2008, 01:40:10 PM »
what application is generating the proxy objects?
could be that r14 just wont proxy them correctly, and then need to be saved-as in a way back way that strips the proxy data from them. Perhaps even DXF'ed out to be more backward compatible.
