Author Topic: CDGpurge 4.0  (Read 9782 times)
CDGpurge 4.0
« Reply #30 on: January 12, 2005, 11:46:15 AM »
Quote from: Andrew H
Hmmm... What's endit.lsp, that sounds really interesting.
A simple little snippet I wrote many years ago. Scroll back up and check ronjonp's post of his edit.
CDGpurge 4.0
« Reply #31 on: January 12, 2005, 12:50:46 PM »
When I get a drawing from an architect, I usually strip it of anything I don't need then turn it into an xref., so loosing groups wouldn't be that bad as long as the walls and important stuff isn't lost.
I do the same :) The lisp does not delete entities out of the drawing. Just all the other crap:
ALL - Named Views, Layer Group Filters, Layer Property Filters,
       Layer States, Registered Applications, Pagesetups, Groups are GONE!!
It's a simple great routine...thanks again Keith. This lisp has saved me countless numbers of hours with drawing cleanup.
Ron
Andrew H
CDGpurge 4.0
« Reply #32 on: January 12, 2005, 01:00:25 PM »
Thanks guys.
Matersammichman
Re: CDGpurge 4.0
« Reply #33 on: June 01, 2006, 08:51:35 AM »
I had heard that the source code was going to be shared.
Is this true or not?
Re: CDGpurge 4.0
« Reply #34 on: June 01, 2006, 09:00:08 AM »
Yes it will be, just as soon as I can get off my butt and stick in the our subversion repository. Sorry, lots-O-stuff going on with me at the moment so please bear with me.
thanks
Andrew H
Re: CDGpurge 4.0
« Reply #35 on: June 01, 2006, 11:14:56 AM »
I'm not sure if everyone is aware, but Autodesk added a Registered Applications to the Purge command (though it's not part of the dialog box, but only through the script version of the command). Here's my button macro:
-purge;all *;n;-purge;R * n
« Last Edit: June 01, 2006, 11:27:20 AM by Andrew H »
Re: CDGpurge 4.0
« Reply #36 on: June 01, 2006, 11:24:39 AM »
I use Keith's endit.lsp for super purging drawings. It is by far the fastest\simplest purging tool I've used.
