Author Topic: CDGpurge 4.0  (Read 9778 times)
pmvliet
CDGpurge 4.0
« on: September 08, 2004, 03:25:12 PM »
Hi everyone...
A while back when 4.0 was put on this site, it worked for a few people and several of us couldn't get it to work. has anyone found a solution.
I really want to be able to run it via a script, but am not having any luck as I can't even get 4.0 to work.
Any ideas?
Pieter
hyposmurf
CDGpurge 4.0
« Reply #1 on: September 08, 2004, 03:47:12 PM »
Yeh Ive downloaded it and the version 4 seems to missing the exe file,the version 2 just doenst work :? Starnge knone on that website has sorted it by now
hudster
CDGpurge 4.0
« Reply #2 on: September 08, 2004, 04:41:05 PM »
I can't find the website for CDGpurge.  I'm using this web address http://www.caddevelopmentgroup.com/downloads.htm but Firefox returns a message saying the site cannot be found.
Am I looking in the right place. :?
hyposmurf
CDGpurge 4.0
« Reply #3 on: September 08, 2004, 05:02:18 PM »
http://www.caddepot.com/dcd1/Autodesk/Utilities/index-8.html
Thats were I found mine,but the exe file seems to be missing.Maybe someone could upload the correct software to the swamp?
CDGpurge 4.0
« Reply #4 on: September 08, 2004, 05:23:57 PM »
I just checked both the web site and the authors e-mail address and neither one is valid.
jroderick_at_caddevelopmentgroup.com
hyposmurf
CDGpurge 4.0
« Reply #5 on: September 08, 2004, 05:32:59 PM »
:shock: Wonder whats going on.
Andrew H
CDGpurge 4.0
« Reply #6 on: September 09, 2004, 10:48:16 AM »
Here is a link (if link doesn't work, I guess you can cut and paste into your browser, if it still doesn't work, let me know and I'll post a zip to the lily pond).
http://theswamp.org/lilly.pond/roderick/cdgpurge40.zip
I was helping Joel at CDG develop this and haven't talked to him in a while, so their site may be down.
If I remember correctly, it took me a little figuring to get the install to work correctly. I had to manually delete all the CDG Purge 3.0 (if you're running an older version, then delete all those files too) and then delete the mapping in AutoCAD. I put these files in a folder I created (mine is CDG Purge 4.0, but you can make it whatever you want), then I remapped AutoCAD to that location. I think it took me a couple tries to get it work right.
Let me know if you still can't get it to work and I'll see if I can write up a 'step-by-step'.
BTW.... there is no .exe file for 4.0, just individual file for manual placement.
pmvliet
CDGpurge 4.0
« Reply #7 on: September 10, 2004, 02:20:49 PM »
Andrew, Do you know if 4.0 is supported by 2002? It works in 2004 on my machine but not 2002.
I'll keep trying.
Pieter
Andrew H
CDGpurge 4.0
« Reply #8 on: September 10, 2004, 02:27:14 PM »
I'm not sure. I think it specifically designed for 2004-2005, but I'll check to see.
hyposmurf
CDGpurge 4.0
« Reply #9 on: September 10, 2004, 03:03:17 PM »
Maybe Im having a brain  :fart:  but when I unzip the above zip file,according to the read me file Im missing the following files
AcadInst.exe
AcadInst.ini
AcadInst.log
Andrew H
CDGpurge 4.0
« Reply #10 on: September 10, 2004, 03:06:23 PM »
No, you're not going crazy, those files aren't included.
I think I just reused the ones from CDG Purge 3.0, but I'm not sure (was a long time ago).
If needed, I'll e-mail them to you or post to lily pond.
hyposmurf
CDGpurge 4.0
« Reply #11 on: September 10, 2004, 03:08:33 PM »
Well I have version 2 with the exe file would that do?If not yes please I would like the exe files.
Andrew H
CDGpurge 4.0
« Reply #12 on: September 10, 2004, 03:11:10 PM »
I don't know if those particular files from 2.0 were modified for 3.0 (which is what 4.0 files are based on).
I'll post to lily pond then a link.
Andrew H
CDGpurge 4.0
« Reply #13 on: September 10, 2004, 03:23:22 PM »
First, uninstall all CDG Purge files and delete all directories (C:\Program Files\CDG...)
Second, install CDG 3.0
Next, copy the following files in to a temporary directory (so to save a copy of them)
AcadInst.exe
AcadInst.ini
AcadInst.log
Next, delete all 3.0 files (including the mapping in AutoCAD), except for the three files in a different directory mentioned above.
Next, install 4.0
Next, move copied files to the 4.0 directory location.
Finally, remap AutoCAD to the latest CDG directory.
If you still can't get it to work, then keep trying. It took me several tries to figure it all out.
Andrew H
CDGpurge 4.0
« Reply #14 on: September 10, 2004, 03:32:28 PM »
Here's a link to the thread where Joel was telling us all about it.
http://theswamp.org/phpBB2/viewtopic.php?p=25043#25043
