Author Topic: Quickest Way To Insert Dozens of Blocks  (Read 1934 times)
M-dub
« on: June 25, 2008, 02:55:45 PM »
What is the quickest way to insert a whole bunch of blocks into one drawing relatively evenly spaced?  They are all in the same directory.  I was just trying to avoid having to insert each one individually.
Re: Quickest Way To Insert Dozens of Blocks
« Reply #1 on: June 25, 2008, 03:17:14 PM »
Lisp of Script I would guess.  Lisp would be My first choice.
M-dub
« Reply #2 on: June 25, 2008, 03:21:39 PM »
I'm half done.  It's not as easy (straight forward) as I first thought, anyway.
Thanks though.  :)
deegeecees
« Reply #3 on: June 25, 2008, 03:27:13 PM »
Pseudo code:
Get names of all blocks plus limits
Get max limits of largest block
Set ins point at 0,0
Increment to the right using units of largest block + a couple units
Insert first block in list
Repeat for a number of times, then increment up/dn using units of largest block + a couple units, etc...
« Reply #4 on: June 25, 2008, 03:38:13 PM »
Here's my stab at it:
(defun c:insertblks (/ d doc lst pt pt1 dir)
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
    (and (setq
   dir (vl-filename-directory
(getfiled "Select a DWG" (getvar 'dwgprefix) "dwg" 8)
(setq lst (vl-directory-files dir "*.dwg"))
(setq pt1 (getpoint "\nSelect point for first block: "))
(setq d
(distance (getpoint pt1 "\nSelect distance to space blocks: ")
  pt1
     (foreach b lst
       (vla-insertblock
(if (= (getvar 'cvport) 1)
   (vla-get-paperspace doc)
   (vla-get-modelspace doc)
(vlax-3d-point (setq pt1 (polar pt1 0.0 d)))
(strcat dir "\\" b)
1
1
1
0.0
M-dub
« Reply #5 on: June 25, 2008, 03:50:12 PM »
Cool, Ron.  That did it  :)
Thanks!
« Reply #6 on: June 25, 2008, 04:02:32 PM »
You're welcome :)
