Author Topic: How Run ARX2009 SDK's HlrArxSample and amodeler  (Read 2759 times)
ahlzl
« on: June 24, 2008, 07:43:47 AM »
1、I compile \utils\HlrApi\samples\HlrArxSample, but load "\utils\HlrApi\samples\HlrArxSample\Debug\AsdkHlrArxSample.arx" fail!
2、I compile \utils\amodeler\samples\asdkbodyapp,fail!
help me, thanks!
It's Alive!
  • BricsCAD
  • AKA Daniel
Re: How Run ARX2009 SDK's HlrArxSample and amodeler
« Reply #1 on: June 24, 2008, 09:12:32 AM »
help me, thanks!
There is a note in the readme that says:
Note:
To use these applications, AsdkHlrApi17.dbx should be copied into the
AutoCAD folder. First the OS must find it and second AutoCAD must find
it for the acrxLoadModule("AsdkHlrApi.dbx",0) call to succeed.
You can find this file in the RedistribXXX folder of the SDK
ahlzl
« Reply #2 on: June 24, 2008, 09:49:03 AM »
oh, Why don't I find this! :oops:
First: Thanks again, great Daniel !
Second : to study HlrArxSample.
and amodeler?
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #3 on: June 25, 2008, 01:26:17 AM »
I had no errors when compiling the solution, what errors are you getting?
ahlzl
« Reply #4 on: June 28, 2008, 05:17:48 AM »
compile——
fatal error C1070: mismatched #if/#endif pair in file 'g:\arx2009\utils\amodeler\inc\massert.h'   g:\arx2009\utils\amodeler\inc\massert.h   54      :oops:
