So you make it easy for guys to make bad decisions? and you feel that is in your best interests? okay ...
You cannot characterize the decisions as bad ... they are merely decisions .. we deal with them and move along ... I get paid to produce what the client wants .. period, end of story ... I don't get paid to convince the client what they want is inadequate, incorrect, or plain silly. That being said, I can maintain thousands of archived drawings for less than I can pay someone to redraw that which is already drawn. That my friend IS in our best interest. Revisions cost money .. we charge $150 minimum per page .. you want to back up ... fine ... that will be at least $150 .. now I can take that $150 and put it in the bank and have Joe copy the previous revision to the current folder, add a revision date and print it out ... OR I can have him sit down and change all of the stuff back to what it was previously, taking a 2 minute job and turning it into potentially several hours. That is being smart ... we don't charge less ... we just don't have to work as hard the second time around.
Here if the client wants a change, we charge him for it, if he wants to change back, we charge him for it. In the last two decades we've had to revert a design less than a handful of times because making a design decision in the first place is a very expensive proposition involving a great level of collaboration in the original decision making process, changing THAT design is something only undertaken with extreme concern and again involving a great level of collaboration in the process. Changing it back is, well, in a word, stupid. Bouncing back and forth between designs seems counterproductive. It is especially so on a lump-sum contracts, requiring contract renegotiations and change order estimates and charges for each change.
The last plans that we had to revert back to a previous design was last week. It could have been redrawn or it could have been retrieved from the archived drawings, what would you do? It is much more efficient to retrieve an already existing drawing than to recreate it. You of all people should understand that, considering your comments regarding the "extremely productive tools" such as xrefs. Oh .. and don't think we don't charge the client .. we do .. we just don't have to put out as much effort as you do for that backup to a previous revision. If I can have a designer retrieve a drawing in 3 seconds for the same fee as having them redraw it, I am being much more efficient.
Your lack of understanding this is likely due to your inability to comprehend the vast stupidity of nearly all people who want a home designed. Many times they pay for a revision, only to realize, they don't like it ... so back to the previous revision we go. This is the normal modus operandi in the architectural field, not the exception.
Back to keeping the old files, how do you handle the multitude of background XREF's that continue to change as the design progresses? Do you lock those as well? What do you do when part of it reverts and part doesn't?
We use the plan which will require the least amount of time and effort to get to the final product.
And what of all the files that use these files as xrefs? Sounds like a hairball to me, or you avoid using these extremely productive tools to avoid the hairball, again, seems counter-productive.
Nope we use them in the architectural field, at least in our office, there are limited xrefs. Outside walls on buildings ... everything else is built upon that ... If the shape of the building changes, then the xref changes, as does all associated drawings. Thus you have a revisioned xref and an original. All xrefs are dynamically pathed.
Incidently, we are talking about a small budget item, mostly less that $300k, some under $100k ... changes are inevitable in the housing industry and must be done as economically as possible.
One more thing .. our archive of electronic drawings have saved our butts in at least 3 cases that I know of ... to the tune of at least $1.2m ... in fact, we are currently fighting a battle over a house built 4 years ago, that supposedly was designed incorrectly. We have the original owners approvals and previous revisions showing where we had done it how they said it should have been, but the owner subsequently changed the plans, we revised, home didn't turn out like they wanted .. we are the bad guys .. now how is that for a load?
