Author Topic: Change crosshair color when switched to paperspace  (Read 13843 times)
« Reply #15 on: September 08, 2004, 09:33:26 AM »
lol, Just for example:
Here is a small reactor lisp that will react to the "line" command. To cancel the reactor just issue a "SAVE" command.
This is a small demonstration for using Reactors to react to a command.
(vl-load-reactors)
(vlr-command-reactor nil '((:vlr-CommandWillStart . StartCommand)))
(defun StartCommand (calling-reactor startcommandinfo / thecommandstart)
  (setq thecommandstart (nth 0 startcommandInfo))
    ((= thecommandstart "LINE")
     (theswamp)
    ((= thecommandstart "SAVE")
     (vlr-remove-all :vlr-command-reactor)
    ((= thecommandstart "QSAVE")
(defun theswamp ()
  (alert "Please wait unitll direct you to TheSwamp...")
  (startapp "explorer" "http://www.theswamp.org/phpBB2/")
  (alert "You may now continue with your line.
         To cancle this reactor use the save command.")
When i get some time, ill see if i can help out more.
bman
« Reply #16 on: September 08, 2004, 09:53:58 AM »
Do you copy this code to a vlisp editor & save as a vlx file & then appload?
« Reply #17 on: September 08, 2004, 10:02:07 AM »
Me? No.
Cut and paste it into your command line and issue the line command. (type "l" <sapce bar>) and then you will get an alert box, then an explorer window will open to the swamp. Then issue a save command to cancle it. (ctrl+s).
Anonymous
« Reply #18 on: September 08, 2004, 10:06:09 AM »
that's pretty cool
« Reply #19 on: September 08, 2004, 10:13:47 AM »
Of course it is?! ...J/K, Glad you like it.
bman
« Reply #20 on: September 08, 2004, 10:32:54 AM »
sorry, that was me...forgot to login (wasn't being sarcastic)
« Reply #21 on: September 08, 2004, 10:44:00 AM »
Oh, i know. The thought of you being sarcastic didnt even cross my mind.
SMadsen
« Reply #22 on: September 08, 2004, 11:00:37 AM »
Quote from: Se7en
Me? No.
No, copy and paste to VIM, then save it in VIM with the extension .007, then setup VIM to colorcode lsp files, then write a WSH script to load .007 files in AutoCAD, then open VIM and ...
ok ok, that was sarcasm  :P
Good job Se7en. I think I'll put that alert into all my VI.. ummm lsp files
« Reply #23 on: September 08, 2004, 11:41:44 AM »
Quote from: SMadsen
*blink* ... Ahhh!? *sigh*
Pay no attention to him everybody, that is how he would do it. (*Se7en whispers* Cause he’s not that good with AutoLisp, so he has to do things five times.)
Stig, i thought you would like VIM because the guy that wrote it is Dutch. (Support those fellow Europeans.) --Ok, those were some bad jokes. ...darn it, I’m loosing the ability to make smartass remarks.
BTW, I like that extension of .007 ...*wink* lmao!
SMadsen
« Reply #24 on: September 08, 2004, 11:52:35 AM »
Hehe
Those dutchies are usually pretty good with computers but you know there has to be an exception to every rule .. I think VIM is it  :twisted:
« Reply #25 on: September 08, 2004, 11:58:53 AM »
*choke* ...Ahhhh! Darnit!! Stig has got me on the fricken run here. I cant think of anything witty to say.
*Se7en starts shaking*
Stig your a big dummy!
...grrr!
Awe crap?!
« Reply #26 on: September 08, 2004, 12:01:08 PM »
...I think its MircoCrappy that is rotting my brain!?
« Reply #27 on: September 08, 2004, 05:09:31 PM »
Sorry, I had a meeting at lunch and i had another "thing" i needed to get done. But i whiped up some code for ya; Give this a try and let me know if it works alright for ya.
(vl-load-reactors)
(vlr-miscellaneous-reactor
   nil '((:vlr-layoutSwitched . ChangeLayoutCrosshairColor-Red)))
(defun ChangeLayoutCrosshairColor-Red (calling-reactor info /)
   (if (not (eq (car info) "Model"))
     (vla-put-LayoutCrosshairColor
       (vla-get-Display (vla-get-Preferences (vlax-get-acad-object)))
       (vlax-make-variant 255 vlax-vbLong))))
bman
« Reply #28 on: September 08, 2004, 07:46:51 PM »
I think ur on the right path... that changed the crosshairs to red when switching to pspace. How do you get it to change to white when you click in a viewport?
« Reply #29 on: September 08, 2004, 08:17:06 PM »
Holly cow man?! Your killing me! ...I dont have the first idea. Ill have to think that one over a bit.
