Author Topic: Lisp Problem  (Read 3706 times)
adrian
Lisp Problem
« on: September 07, 2004, 06:23:54 PM »
Glad to finally find you guys.  I have been looking ever since Cadalog shafted the forum site.
Can anyone tell me what is wrong with the below code.  I am trying to make it easier to cog reinforcing bars in plan, and I found this old lisp.
(defun C:COG ( / BAR COGDIR)
(setvar "cmdecho" 0)
(LATEST)
(setq COGDIR (UANGLE 1 "Up Down" "Up Down" NIL NIL))
 ((= COGDIR "Up")(setq COGANG 90))
 ((= COGDIR "Down")(setq COGANG 270))
(setq BAR 0)
    (while
       (setq BAR (entsel "\nSelect BAR:"))
        (if (not (= BAR nil))
            (DRAWCOG)
        );end if
    );end while
(setvar "cmdecho" 1)
);end defun
(defun DRAWCOG ( / BANG COGANG2 P1 P2)
      (setq P1 (osnap (cadr BAR) "quick,NEA"))
      (setq P2 (osnap (cadr BAR) "quick,END"))
            (setq BANG (RTD (angle P1 P2)))
            (if (and (> BANG 90)(<= BANG 270))
                (setq BANG (+ BANG 180))
            (setq COGANG2 (+ BANG COGANG))
      (COMMAND "PLINE" P2 (POLAR P2 (dtr COGANG2) 300) "")
      (command "pedit" (entlast) "j" (car bar) "" "X")
);end drawcog
Thanks in advance.
Ron Heigh
Lisp Problem
« Reply #1 on: September 07, 2004, 06:34:55 PM »
looks like there is a defun called LATEST that is missing.
Anonymous
Lisp Problem
« Reply #2 on: September 07, 2004, 06:50:11 PM »
Thanks Ron, but I am a bit of a novice when it comes to lisp files.  I cant seem to find anything relating to the (latest) and was wondering if there was a way to bypass/delete this section to get it to work.
Lisp Problem
« Reply #3 on: September 07, 2004, 06:51:41 PM »
It may be possible to simply comment out the line, but the program may not operate as it is designed to.
Lisp Problem
« Reply #4 on: September 07, 2004, 10:39:50 PM »
adrian,
Looks like you were trying to get this routine to work a year ago. :?
http://www.freecadapps.com/phpbb2/viewtopic.php?t=16106&highlight=cog+bar&sid=091e762cdc5fd04eb87a1d7ac1394576
Although the code has changed some.
What exactly is the routine supposed to do?
Can you post a DWG explaning the before and after?
Crank
Lisp Problem
« Reply #5 on: September 09, 2004, 02:59:44 PM »
Quote from: CAB
adrian,
Adrian wrote on Thu Sep 09, 2004 10:55 am:
[...]All it does is draw a line of set length on the end of another line either up or down depending on user input.  Then makes the whole thing a poly line.
I don't know what all the arguments are for, but this can't be very difficult.
@Adrian: What is (LATEST) supposed to do? More info please...
BTW: Is this a command used to draw reinforcement?
