functionAutoCAD variable setting rejected: "filletrad" nil
that has to do with the Fillet Radius variable, but that's not anywhere in your setup lisp...try copying and pasting my code into a new notepad file, select save, change to a directory specified in your file search path, change file type to "all types" and name it 128.LSP. Then in AutoCAD type "AP" enter, load the 128.LSP and then type 128 at the command prompt...
