Author Topic: Need help creating 3D roof  (Read 15432 times)
Guest
« on: June 10, 2008, 11:50:11 AM »
I've got a mostly 3D model of a building.  I want to add the roof so I can have a "complete" shell that I can drop onto a site plan.  The problem is, I haven't really done much with roofs (just a few roof slabs, nothing too complicated) and I'd like to create something that resembles the image below.  Is it possible to "merge" roof slabs to make a continuous roof object?  Or can I cut a hole in a roof (similar to RCP grids)?
Guest
Re: Need help creating 3D roof
« Reply #1 on: June 10, 2008, 11:53:15 AM »
Forgot to mention... AutoCAD Architecture (not Revit).
Maverick®
« Reply #2 on: June 10, 2008, 12:24:50 PM »
I could make a .dxf of the roof easily enough.  I don't know if you can import/use that though.
Dimensions?  Pitch? Is that middle section flat or is it a "hole" that walls are inside?
Guest
« Reply #3 on: June 10, 2008, 01:26:20 PM »
Thanks for the offer.
I was able to cobble something together using individual roof slabs and mitering them together.  It works for what I need.
Thanks again!
« Reply #4 on: June 10, 2008, 02:09:08 PM »
Should have used the roof tool and explored the Gable/No Gable operation and then you should not have needed to merge anything together.
Guest
« Reply #5 on: June 10, 2008, 02:40:57 PM »
No time to go "exploring"... gots to gets this done so's I can get it out da' do'h, yo!   :mrgreen:
daron
« Reply #6 on: June 11, 2008, 05:58:40 PM »
Just for future reference and anybody who doesn't know. Like Mike said, you should use the roof command. After you get your basics worked out, convert it to a set of slabs. Slabs can then be cut, mitered, take materials, etc.
Guest
« Reply #7 on: June 12, 2008, 08:26:34 AM »
That's partially what I did (I used the roofslab command).   I just went straight for the jugular and used slabs from the get-go!
daron
« Reply #8 on: June 17, 2008, 07:31:17 PM »
What I said IS not the same as what it sounds like you did. When I put together a roof object, I build it as much as possible with roof before converting them. I've had to do some roofs a few number of times over in order to get all the slopes and angles into one object. It makes it easier to manipulate the slabs after.
angiebuds
« Reply #9 on: November 02, 2010, 04:07:55 PM »
Well, your plan depends on the roof structure. The individual roof slabs are far better. It would benefit you a good painting experience.
« Last Edit: November 04, 2010, 06:13:27 AM by angiebuds »
