Author Topic: Using 'entdel' to delete a block definition  (Read 4743 times)
Re: Using 'entdel' to delete a block definition
« Reply #15 on: June 13, 2008, 11:17:08 AM »
Hi Tim,
Am I right in thinking the conclusion is it can't be done without some form of detach, at least while the drawing is open?
Regards
Yup Joe.  It seems either you use the command, or the ActiveX controls.  I couldn't even unload an xref in vanilla Lisp.
