Author Topic: How Run ARX2009 SDK's SimpleSquare  (Read 2476 times)
ahlzl
« on: June 03, 2008, 08:19:04 PM »
I compile samples\entity\SimpleSquare, but in samples\entity\SimpleSquare\SimpleSquareUI\bin, I can't find any DLL file!
thanks!
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: How Run ARX2009 SDK's SimpleSquare
« Reply #1 on: June 03, 2008, 09:20:58 PM »
I don't have the 2009 samples available at the moment , but ;
In the IDE ..
Project Menu -> Properties ( at the bottom) -> Build ->
what is the configured output path ( for Debug and Release versions) ?
also, Solution Explorer-> Show all Files ... and have a look in the folders ...
failing that, can you do a file search for the DLL
Called Kerry in my other life
I live at UTC + 13.00
ahlzl
« Reply #2 on: June 03, 2008, 09:36:12 PM »
kbwdt, thank you very much!
