Author Topic: How do you joing parts of a string together in lisp?  (Read 2874 times)
Bob Wahr
« on: May 30, 2008, 10:46:36 AM »
What I want
Sub TEST()
Dim nomen As String
Dim adicio As String
nomen = ThisDrawing.GetVariable("LOGINNAME")
adicio = "p:\acad\drafters\" & nomen & "\support"
End Sub
What isn't working
(defun c:TETHT()
    (setq strname (getvar "LOGINNAME"))
    (addsupportpath "P:\\acad\\drafters\\"strname"\\support" nil) ;with or without spaces or &s
(princ))
Re: How do you joing parts of a string together in lisp?
« Reply #1 on: May 30, 2008, 10:53:43 AM »
I think strcat is what you are looking for
(defun c:TETHT()
    (addsupportpath (strcat "P:\\acad\\drafters\\" strname "\\support" ) nil) ;with or without spaces or &s
(princ))
Bob Wahr
« Reply #2 on: May 30, 2008, 10:59:00 AM »
That's the one.  Thanks.
Trying to get back into some lisp after WTF too many years off.  Should probably find a "Autolisp for freaking morons" book.
« Reply #3 on: May 30, 2008, 11:00:54 AM »
we have a forum dedicated to that ... :D
« Reply #4 on: May 30, 2008, 11:34:37 AM »
A little gem i found a little bit ago i think is absolute genius!
http://www.theswamp.org/~stig/string#4.2.1
DEVITG
« Reply #5 on: June 01, 2008, 11:51:59 AM »
My first ABC lisp book
http://ronleigh.info/autolisp/index.htm
