I use this lisp here at work to export/import room data to and from dwgs. The way this lisp works is that first you pick the pl of an area and then you select the room number. When the function is completed, the room number is replaced with this attribute. The room number and the area is inserted as a field. It works great, but it is inserting the area in the wrong place holder. The area field is being inserted in the last name place holder.
I have looked over this lisp several times to try to figure where to change it. I cannot locate it in the lisp. Can someone please help me out.
