Author Topic: modify pline according to passed vertex list  (Read 2571 times)
subbup
« on: September 03, 2004, 12:20:27 AM »
Hello all,
I need to modify existing pline according to new point_list.
For existing pline data in the form of Xdata and objectdata.
when we changed pline according to new point_list properties should be same.
Any Ideas
daron
« Reply #1 on: September 03, 2004, 08:16:16 AM »
Do you have any code written? Do you want to use ActiveX or dxf code? What's the Xdata for?
SMadsen
« Reply #2 on: September 03, 2004, 08:32:59 AM »
As Daron points out, it can be done by manipulating the pline through the entity list or by updating the coordinates through ActiveX.
Changing the entity list requires a bit more work (or a least some more complex methods) than using ActiveX so I'd go for the latter.
If your point_list is a lisp list in the form of ((x1 y1 z1)(x2 y2 z2) ...), you'll need to weed out z's (if LWPOLY's) and assemble it into one long list. Below is a basic example of doing that.
If your pline is a 3Dpoly - or your point_list consists of 2D points only, you can just append all coordinates like (apply 'append point_list).
The other routine below simply builds the ActiveX data type required for coordinates and replaces the existing coordinates.
Note: These are not complete routines but might provide you with a starting point.
(defun make_coords (lst / new_lst)
  (foreach pt lst
    (setq new_lst (append (list (car pt) (cadr pt)) new_lst))
  new_lst
(defun chpoly (pline point_list / pt_lst)
  (and (not (= (type pline) 'vla-object))
       (setq pline (vlax-ename->vla-object pline))
  (cond ((setq point_list (make_coords point_list)
               pt_lst     (vlax-make-safearray
                            vlax-vbDouble
                            (cons 0 (1- (length point_list)))
         (vlax-safearray-fill pt_lst point_list)
         (vla-put-coordinates pline (vlax-make-variant pt_lst))
