Author Topic: Select all paperspace pviewports - NOT paperspace itself  (Read 13520 times)
mkweaver
« on: May 28, 2008, 12:47:15 AM »
I have programmed for years with lisp, visual lisp, and vba for years, but am just now getting started using vb.net in autocad (as will be obvious by the code and the question).
I am trying to find the annotation scale of all viewports in the drawing. The code below selects all viewports in the drawing and cycles through them, allowing me to get the properties of each one, however, I'm having a hard time excluding the paperspace viewport.  I thought I could identify it as the viewport with the blockname property = "*Paper_Space", but that didn't work.
Suggestions are appreciated.
Mike
  <CommandMethod("SSVP")> _
Public Sub SSVP()
    Dim myDB As DatabaseServices.Database
    Dim myDWG As ApplicationServices.Document
    Dim myEd As EditorInput.Editor
    Dim myPSR As EditorInput.PromptSelectionResult
    Dim mySS As EditorInput.SelectionSet
    Dim mySelectedObject As EditorInput.SelectedObject
    Dim myFilter(0) As DatabaseServices.TypedValue
    Dim iIndex As Integer
    Dim myTransMan As TransactionManager
    Dim myTrans As Transaction
    Dim myViewport As Viewport
    myFilter(0) = New DatabaseServices.TypedValue( _
        DatabaseServices.DxfCode.Start, "VIEWPORT")
    Dim mySF As New EditorInput.SelectionFilter(myFilter)
    Dim myAcadEnt As DatabaseServices.Entity
    myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
    myDB = myDWG.Database
    myEd = myDWG.Editor
    myPSR = myEd.SelectAll(mySF)
    mySS = myPSR.Value
    iIndex = mySS.Count - 1
    myTransMan = myDWG.TransactionManager
    myTrans = myTransMan.StartTransaction
    For iIndex = 0 To mySS.Count - 1
      mySelectedObject = myPSR.Value.Item(iIndex)
      myAcadEnt = mySelectedObject.ObjectId.GetObject(DatabaseServices.OpenMode.ForRead)
      myViewport = mySelectedObject.ObjectId.GetObject(OpenMode.ForRead)
      If myViewport.BlockName = "*Paper_Space" Then
        Debug.Print("Paperspace viewport")
      Else
        Debug.Print(myViewport.AnnotationScale.Scale)
      End If
    Next
    myTrans.Dispose()
    myTransMan.Dispose()
    MsgBox(mySS.Count)
Re: Select all paperspace pviewports - NOT paperspace itself
« Reply #1 on: May 28, 2008, 10:44:58 AM »
Wow, that’s a dang good question. I really don’t know how to differentiate between the two.
Suggestions, assume that the first viewport that is owned by each layout is not the one you want.
Put all the viewports that you want to test on specific layer. Here is an example of the former you can test.
sorry it's in C#... Maybe someone else has a better idea.  :mrgreen:
#region #Using delarations
using System;
using System.Linq;
using System.Text;
using System.Data;
using System.IO;
using System.Text.RegularExpressions;
using System.Threading;
using System.Globalization;
using System.Reflection;
using System.Drawing.Imaging;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.LayerManager;
using Autodesk.AutoCAD.Colors;
//using AcExtensions; mine
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcWd = Autodesk.AutoCAD.Windows;
#endregion
[assembly: CommandClass(typeof(ExecMethod.Commands))]
namespace ExecMethod
  public class Commands
    [CommandMethod("doit")]
    public static void doit()
      try
        foreach (AcDb.Viewport vp in doitsub())
          ed.WriteMessage("\n" + vp.AnnotationScale.Scale.ToString());
      catch (SystemException ex)
        ed.WriteMessage("\n" + ex.Message);
        ed.WriteMessage("\n" + ex.StackTrace);
    public static  IEnumerable<AcDb.Viewport> doitsub()
      List<AcDb.Viewport> head = new List<AcDb.Viewport>();
      List<AcDb.Viewport> tail = new List<AcDb.Viewport>();
      try
          ObjectId ldid = db.LayoutDictionaryId;
          DBDictionary ld = tr.GetObject(ldid, OpenMode.ForRead, false) as DBDictionary;
          foreach (DBDictionaryEntry de in ld)
            Layout layout = tr.GetObject(de.Value, OpenMode.ForRead, false) as Layout;
            BlockTableRecord bt = tr.GetObject
              (layout.BlockTableRecordId, OpenMode.ForRead, false) as BlockTableRecord;
            foreach (ObjectId eid in bt)
              DBObject dbo = tr.GetObject(eid, OpenMode.ForRead, false);
              if (dbo is AcDb.Viewport)
                AcDb.Viewport vp = dbo as AcDb.Viewport;
                if (vp.BlockName != "*Model_Space")
                  tail.Add(vp);
            if (tail.Count != 0)
              tail.RemoveAt(0);
              head.AddRange(tail);
              tail.Clear();
          tr.Commit();
      return head;
« Last Edit: May 30, 2008, 06:52:38 AM by Daniel »
Glenn R
« Reply #2 on: May 28, 2008, 11:19:43 AM »
To see if the current viewport is the paperspace viewport itself (ie in paperspace and not in a viewport):
Database db = doc.Database;
Editor ed = doc.Editor;
if (db.PaperSpaceVportId != ed.CurrentViewportObjectId)
    // not in paperspace viewport
You can also look up the help on AcDbLayout::getViewportArray and note what it says about the first element.
This is wrapped by the GetViewports() method of the Layout object.
Cheers,
Glenn.
« Reply #3 on: May 28, 2008, 11:46:02 AM »
...You can also look up the help on AcDbLayout::getViewportArray and note what it says about the first element.
This is wrapped by the GetViewports() method of the Layout object...
Thanks Glenn  :kewl:
my assumption was right. “The first ID in the list will be the paperspace viewport.”
A version using Layout::GetViewports())
      try
      Editor editor = Application.DocumentManager.MdiActiveDocument.Editor;
          foreach (ObjectId eid in layout.GetViewports())
            AcDb.Viewport vp = tr.GetObject(eid, OpenMode.ForRead, false) as AcDb.Viewport;
              tail.Add(vp);
            tail.RemoveAt(0);
            tail.Clear();
        tr.Commit();
      return head;
Glenn R
« Reply #4 on: May 28, 2008, 11:57:44 AM »
Dan,
There is also a Database::GetViewports(bool)...try that as it would allow you to ditch cycling the layouts and opening each one looking for modelspace...
« Last Edit: May 28, 2008, 12:01:29 PM by Glenn R »
« Reply #5 on: May 28, 2008, 12:16:30 PM »
Dan,
Ha! Where did that come from  :lol:
new code
      try
        ObjectIdCollection vpids = db.GetViewports(false);
        foreach (ObjectId vpid in vpids)
          head.Add((AcDb.Viewport)tr.GetObject(vpid, OpenMode.ForRead, false));
        tr.Commit();
      return head;
« Reply #6 on: May 28, 2008, 12:22:41 PM »
Mike, any chance we can get you to convert to C#?   :-D
« Reply #7 on: May 28, 2008, 12:47:05 PM »
Maybe a better way...
      try
        foreach (AnnotationScale annoScale in doitsub())
          StringBuilder sb = new StringBuilder();
          sb.Append("\n");
          sb.Append("(");
          sb.Append(annoScale.Name);
          sb.Append(" , ");
          sb.Append(annoScale.Scale.ToString());
          sb.Append(")");
          ed.WriteMessage(sb.ToString());
    public static IEnumerable<AnnotationScale> doitsub()
      List<AnnotationScale> head = new List<AnnotationScale>();
        foreach (ObjectId vpid in db.GetViewports(false))
          AcDb.Viewport vp = tr.GetObject(vpid, OpenMode.ForRead, false) as AcDb.Viewport;
          if (vp.AnnotationScale != null)
            head.Add(vp.AnnotationScale);
      return head;
Glenn R
« Reply #8 on: May 28, 2008, 03:59:28 PM »
Much tighter :)
mkweaver
« Reply #9 on: May 29, 2008, 11:20:51 PM »
First, thanks for all the help.  It is really helpful.
This is what I have now, and it works, as far as it goes.
  Public Shared Function doitsub() As IEnumerable(Of Autodesk.AutoCAD.DatabaseServices.Viewport)
    Dim Editor As Autodesk.AutoCAD.EditorInput.Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
    Dim head As New List(Of Autodesk.AutoCAD.DatabaseServices.Viewport)()
    Dim db As Database = HostApplicationServices.WorkingDatabase
    Using tr As Transaction = db.TransactionManager.StartTransaction()
      Dim vpids As ObjectIdCollection = db.GetViewports(False)
      For Each vpid As ObjectId In vpids
        head.Add(DirectCast(tr.GetObject(vpid, OpenMode.ForRead, False), Autodesk.AutoCAD.DatabaseServices.Viewport))
      Next
      tr.Commit()
    End Using
    Return head
  End Function
  <CommandMethod("doit")> _
  Public Shared Sub doit()
    Try
      For Each vp As Autodesk.AutoCAD.DatabaseServices.Viewport In doitsub()
        Editor.WriteMessage("" & Chr(10) & "" + vp.AnnotationScale.Scale.ToString())
      Next
    Catch ex As SystemException
      Editor.WriteMessage("" & Chr(10) & "" + ex.Message)
      Editor.WriteMessage("" & Chr(10) & "" + ex.StackTrace)
    End Try
Now a couple of questions.  I know that to open an object for read I must wrap the read in a transaction.  So, I see that we've done that in DoitSub, but then when we get to Doit, I don't have to wrap that (the code that gets the viewport properties) in a transaction?  I mean, I can see that I don't - it works, but I would have expected a transaction here:-/
If I now want to modify the annotation scale for the viewport, it looks to me like I must:
  • Start another transaction
  • cycle through the viewports in Head
  • re-opening each for write
  • make the modification
  • and commit the transaction
Again, thanks for all the examples.  I'm seeing "slight of code" here that I didn't imagine possible.
Testing continues...
« Last Edit: May 29, 2008, 11:35:11 PM by mkweaver »
mkweaver
« Reply #10 on: May 29, 2008, 11:26:01 PM »
I spent some time with C and C++ years ago (turbo C 3, I think) and was, shall we say, overwhelmed.  I generated a couple of simple console apps, but didn't ever really get proficient.  Because of this, and the time I have with VB/VBA I assumed that I would come up to speed more quickly with VB.net than I would with C#.
Are there things I could do with C# that I won't be able to do with VB?
mkweaver
« Reply #11 on: May 30, 2008, 12:19:36 AM »
And now another question.
I'm now trying to syncronize the viewport annotation scale with the viewport zoom scale factor.  I have the following code:
<CommandMethod("Doit2")> Public Shared Sub Doit2()
    Dim vp As Autodesk.AutoCAD.DatabaseServices.Viewport
      Try
        For Each vpid As ObjectId In db.GetViewports(False)
          vp = tr.GetObject(vpid, OpenMode.ForWrite, False, True)
          [color=red]vp.AnnotationScale.Scale = vp.CustomScale[/color]
        Next
      End Try
      tr.commit
    End Using
But it fails, telling me the scale property of the annotationscale is read only.  The documentation (objectarx for acad 2009) says otherwise:
Autodesk.AutoCAD.DatabaseServices Namespace > Viewport Class > Viewport Properties > Viewport.AnnotationScale Property
C#
public Autodesk.AutoCAD.DatabaseServices.AnnotationScale AnnotationScale;
Visual Basic
Public Property AnnotationScale() As Autodesk.AutoCAD.DatabaseServices.AnnotationScale
Description
Accesses the AnnotationScale associated with the viewport
Conditions
Read / Write
I know that Acad 2009 has a scale syncronize button, but when working with drawings created prior to 2008 (the advent of annotation scaling) the viewport scale factor will be correct while it's annotation scale defaults to 1.  The scale sync button changes the zoom scale factor for the viewport :x Not the desired behavior.
Glenn R
« Reply #12 on: May 30, 2008, 05:00:09 AM »
A suggestion:
In autocad, I generally won't pass around a container of opened objects like you're returning from doitsub.
Instead, pass around an ObjectIdCollection, as this has less overhead and means that you only open objects for read or write when you need them.
mkweaver
« Reply #13 on: May 30, 2008, 07:33:12 AM »
A suggestion:
I hadn't considered that the viewport objects returned by doitsub remained open, I thought committing the transaction would close them.  In this case, then, is there any clean-up that needs to be done with those open objects?
In this case, where I am first reading the scale then modifying it, it sounds like a good idea to use a collection of objectid.
« Reply #14 on: May 30, 2008, 12:09:30 PM »
Exactly,  You could write a class to handle all the methods you need to get/modify the properties.
You could even write a custom struct or class to store your data.
Here are some very quickly thrown together methods that don’t necessarily represent best programming practices, but might give you a few ideas.
using System;
using System.Linq;
using System.Text;
using System.Data;
using System.IO;
#endregion
    [CommandMethod("doitOnce")]
    public static void doitOnce()
      try
        List<AnnotationScale> scalelist = (List<AnnotationScale>)getScaleList();
        AnnotationScale current = scalelist[1];
        Set("Layout1", current);
    [CommandMethod("doitAll")]
    public static void doitAll()
      try
        AnnoDataList annoList = (AnnoDataList)Get();
        for (int i = 0; i < annoList.Count; i++)
          ed.WriteMessage("\nold" + annoList[i].ToString());
          annoList[i].AnnotationScale = current;
        Set(annoList);
          ed.WriteMessage("\nnew" + annoList[i].ToString());
    public static void Set(string LayoutName, AnnotationScale annoScale)
      LayoutManager manager = LayoutManager.Current;
      ObjectId layoutId = manager.GetLayoutId(LayoutName);
      if (layoutId.IsNull)
        return;
        AcDb.Layout layout = tr.GetObject(layoutId, OpenMode.ForRead, false) as AcDb.Layout;
        ObjectIdCollection ids = layout.GetViewports();
        if (ids.Count > 0)
          ids.RemoveAt(0);
          for (int i = 0; i < ids.Count; i++)
            AcDb.Viewport vp = tr.GetObject(ids[i], OpenMode.ForWrite, false) as AcDb.Viewport;
            vp.AnnotationScale = annoScale;
        tr.Commit();
    public static void Set(AnnoData annoData)
        AcDb.Viewport vp = tr.GetObject(annoData.m_viewPortId, OpenMode.ForWrite, false) as AcDb.Viewport;
        vp.AnnotationScale = annoData.m_AnnotationScale;
        tr.Commit();
    public static void Set(IEnumerable<AnnoData> annoDataList)
        foreach (AnnoData data in annoDataList)
          AcDb.Viewport vp = tr.GetObject(data.m_viewPortId, OpenMode.ForWrite, false) as AcDb.Viewport;
          vp.AnnotationScale = data.m_AnnotationScale;
        tr.Commit();
    public static IEnumerable<AnnoData> Get()
      AnnoDataList head = new AnnoDataList();
      AnnoDataList tail = new AnnoDataList();
          if (layout.LayoutName != "Model")
                tail.Add(new AnnoData(layout.LayoutName, vp.ObjectId, vp.AnnotationScale));
              tail.RemoveAt(0);
              tail.Clear();
        tr.Commit();
      return head;
    //KWB
    static public IEnumerable<AnnotationScale> getScaleList()
      List<AnnotationScale> annolist = new List<AnnotationScale>();
      ObjectContextCollection occ = HostApplicationServices.WorkingDatabase.
        ObjectContextManager.GetContextCollection("ACDB_ANNOTATIONSCALES");
      foreach (AnnotationScale a in occ)
        annolist.Add(a);
      return annolist;
  public class AnnoDataList : List<AnnoData>
    public AnnoDataList() { }
    internal string m_LayoutName;
    internal ObjectId m_viewPortId;
    internal AnnotationScale m_AnnotationScale;
    public AnnoData(string layout, ObjectId viewPortId, AnnotationScale annotationScale)
      m_LayoutName = layout;
      m_viewPortId = viewPortId;
      m_AnnotationScale = annotationScale;
    public string LayoutName
      get { return this.m_LayoutName; }
      set { this.m_LayoutName = value; }
    public ObjectId ViewPortId
      get { return this.m_viewPortId; }
      set { this.m_viewPortId = value; }
    public AnnotationScale AnnotationScale
      get { return this.m_AnnotationScale; }
      set { this.m_AnnotationScale = value; }
    public override string ToString()
      sb.Append("(");
      sb.Append(this.m_LayoutName);
      sb.Append(" , ");
      sb.Append(this.m_viewPortId.ToString());
      sb.Append(" , ");
      sb.Append(this.AnnotationScale.Scale.ToString());
      sb.Append(")");
      return sb.ToString();
« Last Edit: May 30, 2008, 12:13:01 PM by Daniel »
