Author Topic: (challenge) convert Julian date to ddmmyyyy  (Read 10926 times)
« on: September 02, 2004, 11:50:57 AM »
Create an autolisp program using Meeus's version of converting a Julian
date to dd mm yyyy. The program shall accept one argument (Julian date)
and return the converted Julian date in in the form of a string and
format of dd/mm/yyyy.
Let JD = (getvar "TDCREATE")
1. Add .5 to the JD and let Z = integer part of (JD+.5) and F the
      fractional part F = (JD+.5)-Z
2. If Z < 2299161, take A = Z
      If Z >= 2299161, calculate alpha = INT((Z-1867216.25)/36524.25)
      and A = Z + 1 + alpha - INT(alpha/4).
3. Then calculate:
      B = A + 1524
      C = INT( (B-122.1)/365.25)
      D = INT( 365.25*C )
      E = INT( (B-D)/30.6001 )
The day of the month dd (with decimals) is:
     dd = B - D - INT(30.6001*E) + F
The month number mm is:
     mm = E - 1, if E < 13.5
or
     mm = E - 13, if E > 13.5
The year yyyy is:
     yyyy = C - 4716   if mm > 2.5
or
     yyyy = C - 4715   if mm < 2.5
An example from Meeus' book is for JD = 2436116.31
     JD + 0.5 = 2436116.81, so
         Z = 2436116
         F = 0.81
     alpha = INT((2436116 - 1867216.25)/36524.25 ) = 15
         A = 2436116 + 1 + 15 - INT(15/4) = 2436129
Then
         B = 2437653
         C = 6673
         D = 2437313
         E = 11
So, dd = 4.81, mm = E-1 = 10, and yyyy = C-4716 = 1957, so the date
is:
     Oct 4.81, 1957
« Reply #1 on: September 02, 2004, 12:02:54 PM »
What?! :horror:
« Reply #2 on: September 02, 2004, 12:14:13 PM »
What........... *shrug*
« Reply #3 on: September 02, 2004, 12:26:11 PM »
I understood like ...ONE word out of that.
Are those instructions on how to convert to ddmyy format? or are they just ment to make me look stupid?
« Reply #4 on: September 02, 2004, 12:31:54 PM »
Quote from: Se7en
Yes, it's really quite easy.
Quote from: Se7en muttered
Well if I can do it ....................
« Reply #5 on: September 02, 2004, 02:15:10 PM »
I tried to make it work with adding the 0.5 to the julian date, but I kept getting the wrong day, after removing it the day came out correct...
I know the theory behind adding the 0.5, and since in lisp, the FIX function does not round, it is not needed.
Here is my contribution....
(defun GDate( JD )
  (setq Z (fix JD)
ALPHA (fix(/(- Z 1867216.25)36524.25))
A (if (< Z 2299161)
   Z
   (- (+ Z 1 ALPHA)(fix (/ ALPHA 4)))
B (+ A 1524)
C (fix(/(- B 122.1) 365.25))
        D (fix(* 365.25 C))
        E (fix(/(- B D)30.6001))
F (- JD (fix JD))
        DD(- B D (fix (* E 30.6001)))
        MM(atoi
   (rtos
     (if (> 13.5 E)
       (- E 1)
       (- E 13)
     2
     0
        YYYY(if (< 2.5 MM)
     (- C 4716)
     (- C 4715)
      ((= MM 1)(setq MM "January"))
      ((= MM 2)(setq MM "February"))
      ((= MM 3)(setq MM "March"))
      ((= MM 4)(setq MM "April"))
      ((= MM 5)(setq MM "May"))
      ((= MM 6)(setq MM "June"))
      ((= MM 7)(setq MM "July"))
      ((= MM 8)(setq MM "August"))
      ((= MM 9)(setq MM "September"))
      ((= MM 10)(setq MM "October"))
      ((= MM 11)(setq MM "November"))
      ((= MM 12)(setq MM "December"))
      (T (setq MM (rtos MM 2 0)))
    (alert (strcat MM " "(rtos (fix DD) 2 0)", "(rtos YYYY 2 0)))
CADaver
« Reply #6 on: September 02, 2004, 02:37:34 PM »
(setq pldate (MENUCMD "M=$(EDTIME, $(GETVAR, DATE),DD-MON-YY HH:MMam/pm)"))
« Reply #7 on: September 02, 2004, 02:44:12 PM »
Quote from: Keith
this *seems* to work for me. could be just an illusion though.
(setq z  (fix (+ jd 0.5))
f (- jd z)
alpha (fix (/ (- z 1867216.25) 36524.25))
David Bethel
« Reply #8 on: September 02, 2004, 03:04:46 PM »
I have the Julian conversion that came with R12 by Kelvin Throop dated 1994.  I also have 1 modified by Duff Kirkland and John Walker dated 1993.
The long 1 is very interesting reading.  Both became very moot with the introduction of Diesel.  -David
15 KB
http://www.davidbethel.com/lisp/julian.lsp
R12 Dos - A2K
CarlB
« Reply #10 on: September 02, 2004, 06:50:48 PM »
If all you are intersested in is the date, then why not use:
(setq longdate (rtos (getvar "date") 2 0))
(setq YYYY (substr longdate 1 4)
        MM (substr longdate 5 2)
        DD (substr longdate 7 2)
(princ (substr MM "-" DD "-" YYYY))
« Reply #11 on: September 02, 2004, 08:53:23 PM »
The whole point of this thread was to get all the hackers (newbies mainly) to write a program using the forumla listed. I wasn't looking for information, it was simply a challenge.
« Reply #12 on: September 02, 2004, 09:22:59 PM »
I was thinking that this would be a good one for someone to get their feet wet with. I actualy didnt get to any code at lunch like i thought i would today, but you basicly did all the work already with those instructions (yes, i have since re-read them.) in the first post. (Although, i still think they were worded in a way intended to make me look stupid.  ...This is a setup isnt it!?)
Anyways, I want to try to get some code down on paper tomorow at lunch. (Im still in a Microstation job so I cant hide the fact that im writing a lisp. :P)
« Reply #13 on: September 02, 2004, 10:30:21 PM »
uStation; ackk.
We've lost him to the dark side folks!
daron
« Reply #14 on: September 03, 2004, 08:14:42 AM »
Speaking of MickeyStation, there's this guy here who keeps singing the praises of MS and keeps calling Autocad archaic. Personally, I think he's full of crap and doesn't know what he's talking about, but then I've never used MS, nor do I want to. His biggest complaint is that he can't, in Autocad, copy multiple items from the start and he keeps telling us that we should put our dimensions in paperspace, because that's the way they did it when he used MS. My guess is, he hasn't used autocad since release 14. I'm just glad he's not in the cad department. He's a project manager.
