Author Topic: Layer dialog in 2009 is larger than screen?  (Read 1858 times)
KewlToyZ
« on: May 21, 2008, 10:46:55 AM »
I'm curious if anyone knows where I can reset the size of this thing?
I'm already at a max resolution of 1600x1200.
Dinosaur
Re: Layer dialog in 2009 is larger than screen?
« Reply #1 on: May 21, 2008, 11:04:05 AM »
try anchoring it to one side and then set it to not allow docking . . . i think it will reset to a point where you can adjust it to suit
KewlToyZ
« Reply #2 on: May 21, 2008, 11:34:29 AM »
Tried that already, it anchors, it docks, but the edge extends off of the screen.
Pretty crazy, trying to see if the dialogs size is in the cui now.
« Reply #3 on: May 21, 2008, 11:36:02 AM »
you might try loading the default VGA drivers and then start CAD, all things should re-size
Guest
« Reply #4 on: May 21, 2008, 11:50:20 AM »
Quote from: Nick Burns, Your Company's Computer Guy
Have you tried rebooting?'
« Reply #5 on: May 21, 2008, 11:52:18 AM »
ssshhhh!
I like them to think that they are not simply rebooting.
KewlToyZ
« Reply #6 on: May 21, 2008, 12:32:07 PM »
Well I'm really looking for where it is able to be controlled in the CAD interface besides the GUI.
I'm beginning to think only the registry can truly handle it.
I was able to fix it using the lower corner with the GUI even though it was nowhere to be seen.
Resetting Windows preferences is a pain, usually just better off re-creating the users profile than trying to fix it 9 times out of 10 when bugs like this come up. Just consumes less time than chasing every possible nightmare. :kewl:
Kate M
« Reply #7 on: May 21, 2008, 01:17:19 PM »
I saw that happen with the Properties palette a couple times...after somebody ran a registry cleaner. :pissed:
« Reply #8 on: May 21, 2008, 01:21:14 PM »
That is why is is ALWAYS suggested that a copy of the DEFAULT profile be exported, backed up, and copied to a SAFE location the very instant that cad is started.
KewlToyZ
« Reply #9 on: May 22, 2008, 09:56:10 AM »
Been there done that as well as the MEP & ACAD cui's.
What is a real pain in the arse is updating networked palettes.
