Author Topic: Audit/recover moves text  (Read 1151 times)
Willie
  • Going nowhere slowly
« on: May 21, 2008, 05:34:11 AM »
Hi
We have received some drawings from a surveyor that we must convert to PDF.
The drawings was created with unknown cad software and exported to dwg. I think the surveyor uses a very old version of Allycad. (http://www.allycad.com/).
When I open the drawings and change the text from standard to Romans, some of the text moves to 0,0,0 on the drawing. Audit and recover also moves the text to 0,0,0.  Wblock does not work either. I still end up with a drawing that is not correct.
The only way to solve the problem is to open it with Caddie (http://www.caddiesoftware.com/index.php) and then exporting it back to Autocad.
Is their a way to solve the problem in Autocad?  And what could possibly be wrong with the drawings?  See the attached file.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Re: Audit/recover moves text
« Reply #1 on: May 21, 2008, 08:18:37 AM »
When I opened the DWG all of the text was already stacked on top of each other and they did not move when edited.
Willie
« Reply #2 on: May 22, 2008, 12:35:48 AM »
Hi Keith™
All the text looks fine when I open the drawing, bus as soon as I audit, some of it moves to 0,0,0 origin.
« Reply #3 on: May 22, 2008, 01:17:26 AM »
Have you talked to the client .. ??
« Reply #4 on: May 22, 2008, 01:24:09 AM »
Audit is fine for me, as is Text Edit  AC2007 Mechanical ( on this machine)
