Author Topic: Minimum distance between two vlax-curve objects  (Read 42756 times)
Joe Burke
« on: May 20, 2008, 12:16:36 PM »
Think about this.
Group: autodesk.autocad.customization Tony Tanzillo <tony.tanzi...@worldnet.att.net> wrote in article <3664CFB1.
93B45...@worldnet.att.net>... Bob - This isn't remotely close to what he needs.
AutoCAD can't find the minimum clearance between two objects as Microstation can.
I think Tony is wrong about this. I wrote an alorithm which works in most cases for any two curve objects. The function is about eight lines of code. Can you guess how it works?
Re: Minimum distance between two vlax-curve objects
« Reply #1 on: May 20, 2008, 03:38:48 PM »
The only way I can think of doing it is by stepping points on one object and using vlax-curve-getclosestpointto to the other object. Then store the two points and distance in a list then sort the list by shortest distance :?
How'd you do it Joe?
VovKa
  • Ukraine
« Reply #2 on: May 20, 2008, 04:18:11 PM »
to use vlax-curve-getclosestpointto on arcs one will have to build an approximation and that is not 100% accurate
« Reply #3 on: May 20, 2008, 06:34:57 PM »
Think about this.
Joe, I haven't seen the thread, but was the reference to the OutOfTheBox application. ?
Joe Burke
« Reply #4 on: May 20, 2008, 10:12:08 PM »
Kerry,
I don't have time for a full reply now.
I'll just say I think Tony meant vanilla AutoCAD. Does some vertical app have a minimum distance tool?
More later...
daron
« Reply #5 on: May 21, 2008, 09:34:13 AM »
...minimum clearance...
ADT can for stair openings, so why wouldn't other apps be able to?
Joe Burke
« Reply #6 on: May 21, 2008, 09:54:08 AM »
I thought I posted this, but later I don't see it.
Here's some beta code which demonstrates the idea. It should work in the vast majority of typical cases. I'm aware there are a few odd cases where it will not. I'm working on those. See inline comments.
Comments and suggestions welcome.
Joe Burke
« Reply #7 on: May 21, 2008, 10:26:59 AM »
Given there's no such thing as 100% accurate within AutoCAD, try the code I posted.
It uses an approximation method for all supported object types because one sub-routine can process all object types. IOW, a lot less code than would be needed if the line to line condition used a specific sub-routine. Which is possible.
Joe Burke
« Reply #8 on: May 21, 2008, 10:36:47 AM »
Something like that, but without using vl-sort. See the MD:ObjObj sub-function in the code I posted.
« Reply #9 on: May 21, 2008, 10:44:26 AM »
Here's my "ghetto-fied" solution... :-D
(defun rjp-getmindistof2curveobjs
       (div / inc len lst n obj1 obj2 pt1 pt2)
  (if (and (setq obj1 (car (entsel "\nSelect first curve object: ")))
   (setq obj2 (car (entsel "\nSelect second curve object: ")))
      (setq len (vlax-curve-getdistatparam
  obj1
  (vlax-curve-getendparam obj1)
    n 0.0
    inc (/ len div)
      (repeat div
(setq pt1 (vlax-curve-getpointatdist obj1 n)
      pt2 (vlax-curve-getclosestpointto obj2 pt1)
      n   (+ inc n)
      lst (cons (list (distance pt1 pt2) pt1 pt2) lst)
      (setq lst (vl-sort lst
(function (lambda (d1 d2)
     (< (car d1) (car d2))
    lst (car lst)
      (grdraw (cadr lst) (caddr lst) 1)
      lst
(rjp-getmindistof2curveobjs 1000)
*removed line creation and added vector
« Last Edit: May 21, 2008, 11:35:59 AM by ronjonp »
« Reply #10 on: May 21, 2008, 11:06:49 AM »
Here is my first try. :-)
« Last Edit: May 21, 2008, 11:11:41 AM by CAB »
Joe Burke
« Reply #11 on: May 21, 2008, 11:37:16 AM »
Hi Alan,
I haven't tried your code, but it looks right.
As I said to ronjonp, there's really no reason to make a list of distances and then use the min or the vl-sort function.
And I think setting step to (/ len 1000) is total overkill. You don't need that many iterations if your code works like mine.
Regards
Joe
« Reply #12 on: May 21, 2008, 11:42:00 AM »
And I think setting step to (/ len 1000) is total overkill...
Regards
Joe
Depends on the length of the items tested...if the lines are 10000 ft long then the check is only every 10 feet  :-P
Joe Burke
« Reply #13 on: May 21, 2008, 11:55:57 AM »
Regards
Joe
Not correct. The length of the objects involved is not an issue. Study my code.
VovKa
  • Ukraine
« Reply #14 on: May 21, 2008, 12:01:27 PM »
my reply concerned Ron's suggestiong, but your tricky approach is a wow :)
